More Electrical issues. Need advice!
Old 01-10-2018, 06:38 AM
Sous's Avatar
Sous
Sous is offline
Received 4,462 Likes on 2,851 Posts
Originally Posted by timmyboy76
The water leaks from ORIGINAL SEALED windshields. The fix, is to have it removed and resealed...I want v to say, up until 01, there were GEM. Now, there's VSM. The GEM's are located behind the light switch. How! water makes it onto the is beyond me, but it does. Up until I had mine resealed, I put a sandwich baggy over it.
I knew that, but when I was typing out my response we were getting ready to head out for dinner and I suppose I had tacos on my mind instead of what I should be writing. I have changed the original post and thanks for following up on my mistake.
Old 01-11-2018, 08:53 AM
clintusaf's Avatar
clintusaf
clintusaf is offline
Anyone have any last suggestions before I drop $550 for a new pedal assembly? Would be nice to know if I can replace it with the much vheaper fixed version.
Old 01-11-2018, 10:02 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
Nah, bud...gem would dry out and all good. I did have a horn blaring/alarm while driving in rain one day. Man, did people lol at you funny, lol....get the window sealed up or you'll know what I'm talking about...
Sous, brutha...i figured that. Thought maybe you were a few deep..😜
Old 01-23-2018, 12:07 PM
clintusaf's Avatar
clintusaf
[QUOTE=clintusaf;17717996]Anyone have any last suggestions before I drop $550 for a new pedal assembly? Would be nice to know if I can replace it with the much vheaper fixed version.[/QUOTE
Problem fixed! Replaced my adjustable pedal with the fixed pedal (dorman from Rock Auto for $59!). No issues so far.
Old 01-23-2018, 12:11 PM
Sous's Avatar
Sous
Sous is offline
Nice job!
Old 01-23-2018, 05:16 PM
ExPACamper's Avatar
ExPACamper
ExPACamper is offline
I wonder how similar or different the sensors are- if they can be transferred from one to the other?
Old 01-24-2018, 08:50 AM
jr2000sd's Avatar
jr2000sd
jr2000sd is offline
I'm having almost the same problem but it happens while I'm driving I have to shut the truck off and restart it and it seems to be fine or it will fix itself right away but the truck acts like it's running on 4 cylinders I've changed almost every since earlier but haven't thought about the pedal but I do not have adjustable pedals I have the fixed one but I did put a new throttle positioning sensor in it and did not change the issue
Old 01-24-2018, 12:37 PM
clintusaf's Avatar
clintusaf
The electrical connection plugs directly in. The connection for the adjustable drive connection(looks like a speedometer cable) does not plug in to the fixed pedal and is not needed. So you can just let it hang free or ziptie it up out of the way.
Old 01-24-2018, 01:30 PM
ExPACamper's Avatar
ExPACamper
I have the adjustable pedals and they were unplugged when I got my Excursion. I plugged them back in, no problems.
What about the TPS sensor? I was wondering if it is possible to remove the sensor from the new fixed assembly and use it to repair your adjustable pedals?
Old 01-24-2018, 01:44 PM
clintusaf's Avatar
clintusaf
I would guess no. The fixed pedal does not have the same housing that has the sensor. I noticed the plug only has 4 out of the 8 pins inside the connection
mossyoak.miss
08-11-2015 09:54 PM
yert37388
1999 to 2016 Super Duty
03-16-2015 08:06 AM
USAF CCM
11-18-2008 10:28 PM
79shovelhead
12-18-2007 08:23 PM
kenzmad
10-21-2005 10:04 AM
Quick Reply: More Electrical issues. Need advice!
