F350 with 5th wheel, need air bags? - Ford Truck Enthusiasts Forums
Old 01-08-2018, 12:06 PM
GT4point6's Avatar
GT4point6 GT4point6 is online now
GT4point6 is starting off with a positive reputation.
I will take deliver of my new 2018 F350 CCLB 4X4 in a couple of weeks.
My current truck is a 2006 Ram 2500 4X4 and it needs air bags on the rear to level for towing, RV is 13500 GVWR. Which is more than the Dodge is rated at, so getting new truck.
The Ram sags with the trailer hitched so I installed the airbags.
Does anyone with a 14k trailer and a 350 use airbags or does the stock suspension handle it fine?
Old 01-08-2018, 01:40 PM
mtnguy mtnguy is offline
mtnguy is starting off with a positive reputation.
You will probably not need air bags. I have a 2017 F350 CCSB SRW 4x4 with a 14,000 GVWR 5th wheel camper. The back of the truck sags a bit, the front of the camper is a bit high, I have 7" of clearance between the truck bed rails and the camper, so all is good.
Old 01-08-2018, 04:33 PM
G-Dad G-Dad is offline
G-Dad is starting off with a positive reputation.
I agree with mtnguy. He also has good taste in trucks and RVs :-)
Old 01-08-2018, 04:34 PM
mrgrayaz mrgrayaz is online now
mrgrayaz is starting off with a positive reputation.
No bags needed. We tow nice and level...
Old 01-08-2018, 04:54 PM
slapshot12 slapshot12 is offline
slapshot12 is starting off with a positive reputation.
My trailer is 14k empty and my 350 is level with a 3k pin weight. The rear overload spring only touches in the back and the front only touches on bumps. I was holding off on air bags until I got the new trailer and saw the set up. I needed them on my previous '15 250, and am glad i don't need them now. Just one less thing to worry about.
Old 01-08-2018, 05:38 PM
GT4point6's Avatar
Perfect, thanks all.
The air bags as just one more thing to air up, air down, etc... glad to see I won't need them.
Old 01-08-2018, 11:42 PM
First Dually First Dually is offline
First Dually is gaining momentum as a positive member of FTE.First Dually is gaining momentum as a positive member of FTE.
That's one nice looking rig slapshot12.
Quote:
Old 01-09-2018, 07:02 PM
Thanks! They've only been together for 2 weeks. Just got the Momentum after Christmas. I'm very happy with both!!
Old 01-09-2018, 08:14 PM
Flyct Flyct is offline
Flyct is starting off with a positive reputation.
Since we’re all showing our great truck/trailer combos here’s mine. Ford/GrandDesign
No airbags but headlights shine high at night with low beam. I rarely tow at night.
Old 01-09-2018, 08:20 PM
radio flyer radio flyer is offline
radio flyer is starting off with a positive reputation.
Hi mtnguy,
What hitch are you using in your truck? Nice looking rig.
Old 01-09-2018, 08:56 PM
Quote:
Originally Posted by radio flyer View Post
Hi mtnguy,
Radio flyer, Im not mtnguy but we have identical trailers and trucks. Grand Design Reflection 337RLS and 2017 F350 CCSB 4x4.
Im using a 37 lb Andersen Ultimate Hitch. The hitch is set at the center height position. I have 7-1/2 clearance between the truck bedrails and the trailer overhang.
The truck bed sags 3 when the trailer is hitched.
Heres a picture getting ready to lower the trailer onto the Andersen ball. Notice the red stick I use to gauge how far to back up. I remove the stick before lowering the trailer onto the ball.
Old 01-09-2018, 09:14 PM
CaptFX4 CaptFX4 is offline
CaptFX4 is gaining momentum as a positive member of FTE.
Looks like a popular combo. Ford / Reflection by Grand Design.
No issues with F350
Old 01-10-2018, 07:05 AM
You good on clearance for turning with the short bed? I need to replace my slider hitch from my 2005 as I am now using the puck to rail adapter and it's putting me way nose high... .tempted to try the Anderson....I feel like the trailer is further back on my new '17.
Old 01-10-2018, 02:55 PM
ssunit1's Avatar
ssunit1 ssunit1 is offline
ssunit1 is gaining momentum as a positive member of FTE.ssunit1 is gaining momentum as a positive member of FTE.
It more depends on the configuration of the trailer nose for clearance in tight turns. I used to have a Reese 20k slider until I got the AUH. The nose of my Coachman is curved enough that I didn't need the slider and I am very happy with the ride and weight of the AUH.
Old 01-10-2018, 05:09 PM
Yep, we have a very square nose 5th. I'll check next time how much clearance I have with the new truck.
We are also considering a GD as our Alfa is getting rather old. Sounds like we would be good with a Anderson if we upgrade. Thanks!
97 airbag control module. Oldschoolcarguy 1997 - 2003 F150 2 10-14-2017 09:11 PM
Long Time Stalker Springercl New Member Introductions 0 08-16-2017 09:50 AM
Air bags for F350 SD tonym1069 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 10 05-05-2017 11:58 AM
2013 f150 fx4 air bag replacement project gdhillon 2009 - 2014 F150 1 11-07-2016 08:08 AM
Air bag recommendations superstroked6.0 Fifth Wheel & Gooseneck RV Towing 1 09-28-2016 03:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
