Rear axle up grade
They are unnoticeable they basicly act like an open differential but they use helical gears to transfer torque to the wheel with greater traction. They are even smoother than the factory limited slip because they don't use clutches and they work much better than the Ford unit.
What 00t444e said. The TrueTrac only has 2 disadvantages relative to an open diff: it costs more and it gives up a LITTLE stability on icy roads. But it'll generally give better traction AND better stability than a factory limited slip, so its only downside there is cost.
Although I can't say for certain that it's stronger than a stock open diff. I've heard that it is, but I can't verify that.
84-250lxt-6.9
04-22-2013 09:22 PM
highway90
02-04-2006 11:00 AM
Boyd
1999 to 2016 Super Duty
01-27-2005 01:09 AM
