5.4 2V passenger side engine knock
My work truck is a 00 f250 5.4 2v obviously with 288k. Every cold start the engine makes this knocking noise (ill post a video of exactly how it sounds) coming from the passenger side that started when the truck hit 200k, its not piston slap, hasnt affected performance nor is there any metal in the oil, just curious as to what the cause of this is? Is there a cure to this? Compression is 180 psi across all cylinders that vary only by 5 psi, i put a camera in each spark plug hole to rule out carbon build up but found nothing that caught my eye. The sounds diminishes drastically once im up to temp and doesnt come back unless the truck has been sitting for a few hours. Any help in the matter would be great theres many videos of this noise with no end result as to what it is.
Its not my video but the exact same sound coming from my truck.
my v10 makes a ticking, almost like the valve tick on a 4.0 jeep engine. I'm assuming it is what you are experiencing as well.
I believe my sound to be the hydraulic lash adjusters. the noise goes away to almost not even audible as the engine warms the PO was using heavy weight oil. I switched it back to 5w30 and the noise is not as loud, and goes away faster. I am going to treat this next oil change with a little bit of seafoam, and hopefully I can get all the gunk deposits off and the truck running quietly again
rthis may or may not be ytour issue, but
My work truck is a 00 f250 5.4 2v obviously with 288k. Every cold start the engine makes this knocking noise (ill post a video of exactly how it sounds) coming from the passenger side that started when the truck hit 200k, its not piston slap, hasnt affected performance nor is there any metal in the oil, just curious as to what the cause of this is? ..... The sounds diminishes drastically once im up to temp and doesnt come back unless the truck has been sitting for a few hours. ....
Oh this aint a bad timing guide or tensioner this is a traight knock coming from the passenger side from what sounds like cylinder 3 and 4, i remember reading that the 4.6 2v had a problem on the passenger side cam oiler valve or something like that, that made them tick but this aint a tick its a straight knock like on the video, I dont have a Kitty so that reules out the exhaust part. We had this this truck on the fleet when it had only 100K using 5w30 oil, doesnt burn a drop of oil either. Could it just be worn out wrist pin?
Possibly -- but you'll have to gelocate it a little better with a stethoscope, IR handheld to locate "hot" spots, etc.
You can also eliminate (pull the COP, the plug into the injector, etc) the ignition or injection to the suspected cylinder with a rod knock, wrist pin issue, etc and the sound should change, sometimes even disappear.
Bottom line: with the mileage, that motor is living on "borrowed time".
Our 2003 Exped 5.4L is doing a very similar thing, loud ticking at startup on passenger side and goes away once oil pressure has built up after 2 min or so. Not a hint of ticking after that. It's been doing this since around 130k and now has 170k, runs great. I've read it's probably the timing chain has stretched, but need to do more research.
What you describe seems like exhaust manifold leak due to broken studs. Mine does the same. One things for certain though- it doesn’t take 2 minutes for oil pressure to build up. If it takes more than 10 seconds you have a tremendous problem.
Is the timing chain oil supply one of the first things to pressure up?
My old push rod engines used to take 2-3 min before oil would come out of the tubes and flow onto the rockers.
What is rubbing to make the ticking?
Ok guys, i used a home made stethoscope (a 1/8 fuel line works great) and the sound definatly is coming from the top end from the passenger side, I unplugged injector and COP with no change in sound (thta rules out a rod bearing and wrist pin bushing) im starting to thing it might be a worn out cam follower, or the cam holding caps worn out. When ever I reseal the front timing cover and valve cover ill take a look.
my 2001 2v v-10 is doing a very similar thing. It is a cold weather noise that it has done for several years in the cold of winter (below 32 degrees) but in the past it has only done it for maybe 30 seconds. It does NOT start making the ticking noise until it has been running for about 1 minute 2. This fall it started getting a bit louder and now takes 2-3 minutes to go away completely. The colder out it is the louder and longer it lasts. I have 168,000 on the motor and I bought the truck new. I have allways kept the oil changed with Motorcraft 5W-20. I would really like to know what you find.
Ok so i used my AE scan tool, and had a knock sensor code (forgot to write it dowm) anyways this code never popped out before so decided to install a new one. I did the usual removing intake manifold cleaned parts etc, and sure enough apparently a rodent decided to eat the wire insulation from the knock sensor and both wores were exposed and touching each other. Git everything button up and to my surprise at the first start the knock wasnt there no more literally it disappeared, im guessing this sensor was giving out along time ago and the chewed wires gave the code away. What i still dont understand is why is the sound coming from the passenger side on my truck and on all trucks that ive seen on You tube?
Here's is a pic of the KS
and the new one in the truck
You can data log to rule it out and never in a million years did I thought of data logging to see what what my timing was, technology I have it but sometimes I overlook the little things, who would of thought a sound that sounded mechanical was just timing getting retarded. Hope you guys that have a knock data log and see if your timing isnt getting skewed by a faulty knock sensor and hopefully its an easy fix like mine was.
i also test drove the truck and the knock is gone, when ialso when lugging the engine up hill I had a bad spark knock and it too went away.
