Cranks, but low spark and no injector pulse, no start
Hey guys, I recently replaced my cam phasers and upon putting the engine back together (5.4 3v) the truck will crank but wont spark! I've narrowed it down to having potentially weak spark and no injector pulse. The truck will almost start with starting fluid, but not quite. The ignition coils are reading at 12v correctly but the other side is only reading at 250 millivolts... Does anyone know what the reading should be or if that is correct? The PATS system checked out fine and so did the fuel pump and fuel control module as well as the intertia switch and fuses. I've already replaced my crankshaft position sensor and both camshaft position sensors were recently replaced along with VCT solenoids. It almost seems as if it's a problem with the PCM not sending enough signal to the ignition coils to get it fully firing. I'm not sure where to go from here as i've had a tech come to my house and check it out and i've spent numerous days researching this problem. Would anyone be able to shed any light? I would appreciate any help!
It almost tries to start!.
It's not a spark or fuei injection failure if that is what you see.
The computer only supplies ground and 'removes it' to the coils in the fire order and applies ground to the injectors in the same fire order but off set in time, since 12 volts is already standing on both the coils and injectors from a common fused feed.
Good luck.
Good luck.
X2. It ran before...after you put cam p hasers in it doesn't run.....Yep timing is off.
Desireg
09-25-2015 05:22 PM
cswett
Modular V8 (4.6L, 5.4L)
07-04-2011 05:17 AM
