2000 Excursions wonít start - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
Old 01-07-2018, 02:09 PM
93F250's Avatar
93F250
93F250 is offline
93F250 is gaining momentum as a positive member of FTE.
2000 Excursion V10 4wd. Will crank all day but wonít start. No power at coil when key is on. Fuel inertia switch didnít move when I pressed it. Battery is good. Fuses in dash all have good continuity. Swapped fuel pump relay with another under hood. Will not start on ether. New battery in key fob. No codes. Iím not certain if I hear fuel pump with key or not. I hear something running for a few seconds but sounds like itís in dashboard. With no spark, Iím not sure fuel pump will matter at this point. Looking for hints and will keep digging and updating this post as I try more things.
Old 01-07-2018, 02:13 PM
93F250's Avatar
93F250
93F250 is offline
Only have 1 key. Iím quite certain thatís all it came with. 236,241 miles. Completely stock to the best of my knowledge. I bought it almost 2 years ago for parts/maybe a project and it hasnít left my yard since. I am using it this winter just to pull my other vehicles out of my driveway in case they get stuck in snow.
Old 01-07-2018, 02:28 PM
projectSHO89
projectSHO89 is offline
projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.
If you have no power to the coil, then that is what you need to focus on since the engine cannot run without power to the COPs.
Start with the PCM Power Relay and the fuse(s) that run the PCM. If the PCM doesn't power up, everything downstream, including the fuel pump, is irrelevant.
Old 01-07-2018, 04:05 PM
93F250's Avatar
93F250
93F250 is offline
Every fuse in cab has good continuity. I continuity tested every ecm and pcm fuse under hood. I swapped a couple relays around. No difference. It started hard last I started it a week or 2 ago but it did start. It sits a lot. I added 5 gallons sort of gas as it was pretty low.
Old 01-07-2018, 06:35 PM
projectSHO89
You need to think of how the parts function in the system, not just as individual parts.
Old 01-07-2018, 06:39 PM
93F250's Avatar
93F250
93F250 is offline
Absolutely. Just listing everything I checked.
Old 01-07-2018, 10:23 PM
projectSHO89
I mean, you need to test it AS A SYSTEM, not as individual components.
Old 01-08-2018, 10:53 AM
Krewat's Avatar
Krewat
Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
When you first turn the key to ON, does the check engine light and a bunch of other stuff light up on the dash? The important one is the CEL. If it's not lit, there's no power to the PCM.
Power to the COPs - how did you check it? With the key on, check for +12V between each wire and ground. The +12 feed to the COPs should be red with a green tracer. If there's no +12V there with the key on, there's a very limited amount of things that can go wrong.
Report back with answers to the above.
Old 01-08-2018, 11:42 AM
93F250's Avatar
93F250
93F250 is offline
Iíll have to get back to you on the CEL as Iím not home right now and I donít recall.
With the key on, I checked both wires on 1 coil for power. Nothing on either wire.
Old 01-08-2018, 11:54 AM
Krewat's Avatar
Krewat
Nothing between each wire and GROUND? Then you have to trace back into the wiring if all fuses are good, and relays. The PCM relay gets power from the same junction as the COPs it seems.
For my 2001, but should be the same:
Old 01-08-2018, 04:04 PM
93F250's Avatar
93F250
93F250 is offline
Correct. Key on, checked for voltage from each pin with a multimeter. No voltage.
Old 01-08-2018, 05:00 PM
projectSHO89
Check for power on both test points of F30 (ignition switch in RUN).
outnumberedone
09-21-2015 03:31 PM
aortizexcursion
Ford Truck Parts for Sale
01-08-2013 04:00 PM
perryg114
09-30-2010 06:18 PM
akalawrence
11-03-2003 03:17 AM
explorerdad
09-05-2001 07:39 PM
Quick Reply: 2000 Excursions wonít start
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
