Rear & Side door latch problem (doors open correctly) - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > 1968-2013 Full Size Vans
Reload this Page >
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 01-06-2018, 10:19 PM
myf16n
myf16n is offline
myf16n is starting off with a positive reputation.
First time caller, long time listener. Great forum, and I've already found great info here (mostly in the diesel section since I have a 6.0). I have a 2008 E350 extended with 6 doors (no slider) and only 47k miles. It has only seen light duty as a family van. It was never a work van, and as such was never abused.
I searched and was unable to find anything related to the problem I'm having with the upper latch of the left rear door, and the rear passenger side (suicide) doors.
Let me start by saying that the side and rear cargo doors open and close properly with the inside and outside handles.
The problem I'm experiencing is that the upper latch on the left rear, and passenger side suicide doors will un-latch when I'm driving. I can tell when it happens because the doors will begin to rattle. I confirm they unlatch because I can grab the upper portion of the door and pull it away from the door frame.
I initially thought that I wasn't closing the doors hard enough, but I was able to confirm that wasn't the case. I closed the doors with a firm swing, and when I grasp the tops of the doors and pull, there is zero movement. They always latch.
Has anyone else had this problem? Are the upper cables / latches adjustable? Can anyone point me to the right thread or YouTube video?
Thanks!
Old 01-06-2018, 10:39 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Yes these latches have issues. The latch itself is not adjustable but the striker on the door frame does have some adjustment range so give that a try.
Old 01-06-2018, 11:28 PM
myf16n
myf16n is offline
Thanks, I'll try that!
bigtexan99
32
09-18-2016 05:59 PM
Glowplugger
1999 to 2016 Super Duty
01-26-2016 09:09 PM
F-350PSD
12-08-2008 12:36 AM
Heavenword1
Aerostar
01-31-2007 12:36 PM
jeff_67cougar
Aerostar
13
02-10-2004 10:03 PM
Quick Reply: Rear & Side door latch problem (doors open correctly)
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
