Help with setting up my 03 crown Vic swap in79 f100 - Ford Truck Enthusiasts Forums
Old 01-05-2018, 09:59 PM
Birdman1704
Birdman1704 is offline
Birdman1704 is starting off with a positive reputation.
Not sure on how to make the brackets & put them in the correct position so the alignment comes out correct. In the lower control arm . thanks
Old 01-07-2018, 07:42 PM
loudfords's Avatar
loudfords
loudfords is offline
loudfords is a name known to allloudfords is a name known to allloudfords is a name known to allloudfords is a name known to allloudfords is a name known to allloudfords is a name known to all
You'll get a faster more thorough answer on the crown vic swap facebook group.
Old 01-07-2018, 08:01 PM
Birdman1704
Help with setting up my 03 crown Vic swap in 79 f100
Thanks for the info I'll give it a try
Old 01-11-2018, 03:28 PM
monkey-1
monkey-1 is offline
monkey-1 has a good reputation on FTE.monkey-1 has a good reputation on FTE.
Any pics of your conversion so far?
Old 01-11-2018, 07:12 PM
Birdman1704
This is what i've done so far
Old 01-12-2018, 03:08 PM
monkey-1
monkey-1 is offline
Looks like you are off to a good start. Most people flatten out the rear mounts and make a bracket that attaches to the frame. As you have yours, and as they are removed from the car, they are on an angle. I made brackets keeping them on an angle with hole large enough to adjust the rear mounts for proper alignment.
Edit--Adding pic. This is a 1985 frame and will look different than yours, but the concept is the same.
Size:  78.9 KBName:  045.jpg
Old 01-12-2018, 06:31 PM
flowney's Avatar
flowney
flowney is offline
flowney is gaining momentum as a positive member of FTE.
This is a closed group so I asked to join, answered the question asked and an now patiently waiting to be allowed entry.
Old 01-12-2018, 08:35 PM
Birdman1704
yeah sure join the group everybody's here wants to listen to what somebody else has to say
Old 01-12-2018, 08:37 PM
Birdman1704
Attachment 255390Attachment 255391
the frame it was rolled and I had to heat it and turn it so it was straight but I'm not sure if I had a cut that section so I can make the angle I know it has to be 33 in apart from center bolt center bolt that's where I'm kind of stuck if I should cut that and then box everything or what
kylant
2017+ Super Duty
145
09-21-2017 09:54 AM
sodly
15
07-03-2017 04:47 PM
DisneysPatB
06-22-2017 01:30 PM
PapaBearYuma
01-11-2017 10:21 PM
petei
2017+ Super Duty
12-05-2016 11:53 AM
Quick Reply: Help with setting up my 03 crown Vic swap in79 f100
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
