Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Broke passenger front outer axle ujoint
Old 01-05-2018, 12:38 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
Went out with the local 4wd club on new years day for the annual Hang Over run. broke the front ujoint climbing a cinder pit.
these ujoints had been replaced about 8yrs ago with spicer 760x joints. caps tac welded to the ears.
thoughts are going with a D50 stub shaft/slip joint and then running 4340 chromo axles and againi 760x ujoints. Anyone have experience running these chromo axles? Looks like JBG is my only resource for them?
RCV's are out of my price range and if i planned on that kinda beef might as well go SAS and a 60.
I never plan on running anything larger than 37" tires.
I have an Aussie locker and 4.88's up front.
here is the Video, sorry if it shows up sideways.
http://www.supermotors.net/getfile/1...broncobust.mov
Old 01-09-2018, 07:17 AM
rla2005's Avatar
rla2005
rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Ouch........
Old 01-10-2018, 06:42 AM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
My4Fordtrucks is gaining momentum as a positive member of FTE.My4Fordtrucks is gaining momentum as a positive member of FTE.
I guess the question you need to ask yourself is “Where do you want the weak link to be?” If the u-joint becomes stronger than the diff gears, then that is what will break next time.
Old 01-10-2018, 06:04 PM
Kemicalburns
I would think a hub would go before the Ring/Pinion would no? i am running the standard warn hubs. something to consider for sure though.
Old 01-10-2018, 11:43 PM
ZombieSlayer's Avatar
ZombieSlayer
ZombieSlayer is offline
ZombieSlayer has a good reputation on FTE.ZombieSlayer has a good reputation on FTE.
I had always thought that a hub would go before a u-joint?
Old 01-11-2018, 04:25 PM
mwm4.2tdi's Avatar
mwm4.2tdi
mwm4.2tdi is offline
mwm4.2tdi is starting off with a positive reputation.
was the uni original,non greasable,hubs have a heap of splines,
KaBar
13
08-24-2016 05:10 PM
harrisman5
10-23-2014 07:22 PM
Lukes66
08-19-2014 02:18 PM
barnbuoy
1999 to 2016 Super Duty
03-25-2007 12:42 PM
whalerron
02-08-2005 09:51 AM
Quick Reply: Broke passenger front outer axle ujoint
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
