Enerburn results
Enerburn results
To start off my '15 is an F350 with the 3.31 rear end and currently has 73,xxx mi. I started using Enerburn fuel additive in my 550 gal bulk tank about a month ago, so my truck has seen roughly 4 fill-ups. Fuel is BP Supreme Diesel.
This truck has only ever seen a few fill ups outside of my bulk tank since new. I had the DPF% screen added shortly after I bought it new, so I have been watching it for almost 3 years.
What I am observing is almost unbelievable as prior to the Enerburn additive the truck would add 5% every 35-40 mi. On the first tank I started noticing that figure extending to 45 mi. and by the time I added fuel it had went to 50 mi.
So I am on my 4th fill up and yesterday the truck is at 115 mi. and still at the same %!
I must add that this time of the year I haul light loads, my driving consists of 50% highway/ 50% city driving, and no towing.
I had generally observed that my regens occurred at the 500 mi. mark and sometimes at 90%-95%. The trucks last regen had been cut short due to me reaching my destination, so it was at 55%. Currently its at 70% at 325 mi. (I reset trip 2 at the start of every regen).
Has anyone else experienced results such as these? Its almost unfathomable that a fuel additive can accomplish this.
The EnerBurn Diesel Fuel Performance Catalyst - Enerteck Chemical Corporation
An update; I had to make a 240 mi. trip today, so it worked out I got to have a regen.
For starters my previous regen I had to cut short, only down to 55%. I went the full 500 mi. today and I stood at 80%. Regen only lasted 16 mi. and took me to 45%.
I had noted previously that I had went 115 mi. to gain 5% on DPF dash gauge, so again today I traveled over 100 mi. to gain another 5% finally reaching 80% and 500 mi.
Enerburn is almost unbelievable as I have never used anything that not only works as advertised, but exceeds expectations.
I also want to note I left this morning and air temp was -8F, and on the return trip it had warmed to +8F.
There is an initial period of 3-4 tanks where stuff being cleaned out seems to produce more soot then it goes the other way. A long drive (100 miles or so) can help get it going. When you start, use 1 oz per 20 gallons, and after 4 tanks, 1 oz per 25 gallons.
Sounds like this is worth trying. Are you using any other fuel additives, like Stanadyne or PM-22, along with the Enerburn treatment at fill ups?
There are a few other threads on Enerburn. The marketing literature reads like many additives: by the end of the blurb you begin to think it will cure cancer, cause world peace, etc. But there is a fair amount of scientific testing, published in peer reviewed journals, documenting the effect claimed for the ingredients in it.
My average was something like 280 miles between regens, after 5 tanks it is at 430 and climbing. I don't believe in the marketing claims of additives, but I do believe in hard data.
I contacted a distributor and she will ship it to me in AK, it's almost more to ship than the actual product costs, so I just have to decide if it's worth it.
2 - 16 oz. bottles end up costing me around $112... Debating on waiting until the summer to get some because I will be in the L48 at one point in the summer.
In the winter I can usually watch passive regen occur. I can literally watch my percentage go backwards sometimes. If it weren't for the increase in idling the dpf% would barely grow. In the humid summers I tack on dpf % like every mile it seems. Does this stuff work as good in the summer? Or idling?
