Transmission slipping into nurtral.
Old 01-04-2018, 04:13 PM
Jon39's Avatar
Jon39
Jon39 is offline
i have 06 F150 5.4. Has about 160k on it. For a while the trans would skip or buck between gear wen cruising . The other day I was driving and it just stoped all togather. When I turn over drive off I can drive fine but will not go out of 2ed gear. With the od on it drive fine till I hit 35-40 mph and then acts like it is in nutral. If I really give it a lot of gas it will catch for a second and go then kick back out but still will not go to 3rd. I changed the fluid and filter and was no diffrence. I took it to a shop and but a big computer in it and it has thrown no coads at all so there is nothing to read. Wondering if it could be a speed sensor or if I’m looking at a new trans?
Old 01-04-2018, 05:37 PM
F150Torqued's Avatar
F150Torqued
F150Torqued is offline
@jON39 you need a different shop if they "put a big computer on it and there is nothing to read".
Our trucks provide a wealth of OBDII information on the transmission. There are somewhere around thirty parameters that can be read with a capable live data scanner. Such as 'commanded line pressure', 'line pressure', input shaft RPM, output shaft RPM, calculated gear ratio (Input-to-Output), solenoid status, Torque converter slip, gear number, and on and on. If you have Torque Pro App - I can provide you about 30 custom PIDs you can input into Torque and read yourself.
Edit: Add Screen capture
Transmission scan
Old 01-04-2018, 06:04 PM
Jon39's Avatar
Jon39
Jon39 is offline
I do not have that app but I will try maby a dealer? This was a ssnapone one but I’ll try that thanks
Old 01-04-2018, 06:43 PM
46fordtruck's Avatar
46fordtruck
46fordtruck is offline
Sounds like what mine did @ 160k. I had to have it rebuilt, there were internal components that crapped out. Good luck, hopefully it's something not as bad.
Old 01-05-2018, 06:07 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Time for a new/rebuilt transmission.
Old 01-16-2018, 08:56 PM
mikebaby's Avatar
mikebaby
mikebaby is offline
The same thing is happening to my 2004. Shop said the tranny needs rebuilt or replaced. So I’m replacing the tranny and everything else with a new F250.
mikebaby
Old 01-18-2018, 09:23 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
You have a direct clutch problem. Only way to fix it is to rebuild or replace.
Old 01-18-2018, 09:27 PM
flyguy108's Avatar
flyguy108
flyguy108 is offline
Find out where your local municipality takes its vehicles to have trans work done and take it there. You probably need a rebuild.
Old 03-28-2018, 09:39 PM
oldtimer35's Avatar
oldtimer35
oldtimer35 is offline
You broke the overdrive band and the trans should be rebuild. Did the same thing on mine at about 185K.
Akita Best
03-23-2019 01:42 PM
hunt3r
08-03-2013 10:24 PM
kupaa
10-25-2010 02:52 PM
willyt2000
2004 - 2008 F150
03-13-2010 07:05 PM
Kenny Bonnell
1997 - 2003 F150
13
07-02-2005 07:55 AM
Quick Reply: Transmission slipping into nurtral.
