4.6 p0300, p0303, p0305 ??
I think there was some restriction in the fuel filter but it faulted going downhill, makes no sense but it could be. It appears I am getting better gas mileage so maybe those iridium autolites aren't to good they were a little black on one side maybe fouling occasionally which could have been the problem. The boots were swollen a little and not from oil or water so maybe they could have had something to do with it. The air filter was dirty but I doubt it was the problem. There ya go that's what I think. Oh I did spray the mass air sensor down with cleaner but I don't think it did anything as it was clean.
NOTE: Melted cats are the END results of misfires not the ORIGINAL cause.
Misfires allow unburnt gas to burn in the cats raising their temperature to over 900 degrees.
They are not designed to run at those temperatures. Only just hot enough to treat the exhaust gas at about 600 degrees.
Letting multiple misfires go too long becomes very expensive..
Good luck.
Good luck.
Good luck.
Good luck.
Bad Bad Leroy Brown
42
09-04-2019 09:42 PM
Bad Bad Leroy Brown
16
12-06-2015 08:50 PM
