96 F250 351w 5.8. Cranks but no start HELP
#107
of course it hasn't rained in like 9mo but picks today.
someone told me if the distributor is off a tooth or two it won't let it start without spray that's why popping out tbi when I try to gas it. or it's 180 out.
Im really wondering about timing now I read ur post subford.
I need to start like I took out dizzy and didn't mark it and get it in time. But I know the flat spot on distributor housing ls pointing at driver headlight like where the icm would be if it was on the distributor.
The rotor was pointing like 2 past no1 when I pulled it for pip swap. So I made sure it pointed in same direction when I seated it back in Kinda not sure how that won't work but I'm up for trying anything at this point man
#108
Ok subford
i bumped motor over til puffed out #1 attaching photos showing the white mark and where rotor is pointing.
It appears the left edge of the rotor contact is right at the right side of the #1 contact inside distributor (so it would have just fired the no1 plug?)
the mark looks to be ccw past the timing mark??
#109
#110
#111
You must always turn the engine in running rotation and never back up.
#112
Headingnout now to see if it'll fire while moving distributor
ok so much for that. Either it won't start or battery is drained too much or both. I charge battery some and it'll start with spray fast but dies tried to flutter gas enough to move distributor around but it's too hard to do that.
It don't seem to have any change on firing up tho I cranked it a good bit while moving distributor now I have charger on battery
what's it mean since it don't matter you thinking timing is close enough since it starts with spray or no coz it pops out tbi if I try to throttle it any?
Right after it dies (using shot to start it) if I try to start it again it fires like it tried to start but don't take off. Only does this once or twice then back to cranking
#113
Don't know what the spout is
dont matter coz it won't start and run on its own still.
Ok had wife crank it while moving distributor and it does not help any.
This is may sound stupid but could it be popping out the exhaust and not the tbi??? Does that mean anything different??
askijg coz I shot it to get started and worked throttle so it would pop but it wasn't visible at the tbi idk if it's coz the butterflys were shut too much for it to actually be seen st the tbi?
I don't know at this point I'm at the mercy of what ya think is wrong subford.
#115
I ordered the fuel pressure tester from amazon
its 140$ to rent one so I'm just buying the 32$ one.
#116
#117
wondering if I shouldn't address the timing again at this point or just wait til I can test fuel pressure while cranking tomorrow??
#119
