Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Dead 351m to possible 5.4l Triton swap questions 78 bronco
Old 01-03-2018, 09:12 AM
parker_shelton
parker_shelton is offline
parker_shelton is starting off with a positive reputation.
Alright well I had my motor running the way I wanted finally and a lose belt cut my radiator hose and blew the motor. Its my daily driver and I need it on the road now. I have a 97 or 98 expedition sitting in my driveway that won't pass inspection for a number of reasons but the motor runs pretty well and way better than the one that just blew. I'm low on cash and I've gotta figure out how to get the 5.4 in the bronco. I figure it can't be the worst thing in the world seeing as how I have a whole donor but I need to know what the motor and trans need to run. Please help
Old 01-03-2018, 09:41 AM
Conanski's Avatar
Conanski
Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Pretty much everything that isn't sheetmetal unfortunately since the dash cluster and various safety and anti-theft systems are linked to the Powertrain control system. Yes this project is doable with a donor vehicle on hand but it's not going to be a quick weekend project.
Old 01-03-2018, 10:05 AM
parker_shelton
And I'm assuming there's no way to bypass that stuff
Old 01-03-2018, 10:32 AM
parker_shelton
Why isn't it just like the plug and play aftermarket kits
Old 01-03-2018, 06:26 PM
RalphXL
RalphXL is offline
RalphXL is starting off with a positive reputation.
An aftermarket EFI kit would do away with the security stuff. You would need to make sure that whatever you get will be able to control the transmission too.
Jess
Old 01-03-2018, 08:38 PM
Conanski's Avatar
Conanski
Yeah that is the problem with aftermarket EFI sytems, beside the rather steep cost for what you get they have no provision for transmission control so you have to buy something else or reuse the stock PCM. A tuner should be able to eliminate features of the stock system that you don't want but again there is more money you have to spend.
Old 01-04-2018, 08:39 AM
diymirage
diymirage is offline
diymirage is starting off with a positive reputation.
what about getting rid of the efi all together?
get yourself a 4 barrel intake manifold and run a carb on it
i dont know if you can go back to a distributor but that would be the next hurdle
and then see if a manual valve body (or its mechanical equivalent) is an option
not sure if any of it is possible, but it sure seems like a hassle
Old 01-04-2018, 08:16 PM
fe390pc's Avatar
fe390pc
fe390pc is offline
fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.
That 5.4 is a very wide engine too. You would be better off trading the Expedition for a 351 or 400 that would be a bolt in option. I think the fab work needed for the 5.4 swap is doable, but I would bet you are down no less than two months and 5 grand in cash before it runs.
Old 01-04-2018, 09:00 PM
Conanski's Avatar
Conanski
Most of that is not possible, these modular motors were never equipped with a distrubutor so there is no where to add one, and I'm not aware of any carb intakes for them either.
Old 01-04-2018, 10:55 PM
One eyed Jumpin Jack
One eyed Jumpin Jack is offline
One eyed Jumpin Jack is starting off with a positive reputation.
This whole swap thing is a bad idea. I'm not a fan of the 5.4 to start with (especially an early one) and would never consider it an upgrade in a Bronco. Depending on the year of the Bronco, it would be much much more involved than you think. And all for a smaller displacement, less desirable replacement IMO.
What do you mean by blew the engine? If it's just a cracked head, you can probably take care of that pretty easily. If you locked it up, consider it a lesson to be more obsevant in the future. Did you not smell the coolant while you were driving? I would have pulled over immediately.. Just last week the thermostat housing let go in my wifes Mountaineer. She was at least observant enough to shut it down before "blowing" it up. She got to drive my Bronco for a few days and was a little sad when I got her car running again.
If you KNOW your block is ruined, the cheapest and best way forward would be a junk yard 351 or better yet a 400 motor from a Lincoln or F series. A direct bolt in would be the way to go and down the road the aftermarket efi would be a possibility and you wouldn't have to worry about any tranny computers. Right now it sounds like you just want it to start and get you to work. You sound young, not an insult by the way. Just an observation. I kinda doubt you've attempted a project so involved as the restomod you're dreaming of, otherwise you'd be a bit more hesitant with the idea.
Old 01-07-2018, 07:07 PM
fe390pc's Avatar
fe390pc
fe390pc is offline
So lets get more info on the "Blown Motor"? What is blown about it? Did a rod come out the side of the block, did it overheat, did it seize what is it doing now? You may be able to fix what you have for much less than the swap you are asking about.
Xx0573
Modular V8 (4.6L, 5.4L)
07-03-2013 11:32 PM
AngeliasDad
33
06-01-2011 09:44 PM
poffutt
03-12-2007 10:44 AM
Robart
2004 - 2008 F150
09-01-2004 01:09 PM
Vaccuum
1999 to 2016 Super Duty
68
05-26-2002 09:03 AM
Quick Reply: Dead 351m to possible 5.4l Triton swap questions 78 bronco
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
