I have recently Been in contract with
TSM MFG Co about his front Bolt on disk conversion for my 1951 Ford F3
I also asked him if he had something for the Rears. He currently Doesn’t but is willing to work with me on making a set that will work
With our F3s and fix a problem that many of us encounter with these Widow Maker Tires .
I do need some help with some information he asked me. And I can’t get him the info without taking apart my Axle .
I’m currently using the standard Timken Axle on the early 1951 Ford F3
Please if any of the info required please reply thank you
I junked my Timken rear axle in favor of a Dana 60. So I can't get you measurements.
But I am interested in knowing what this guy said about a front disk conversion.
Tom
Tom
i have my Timken all apart for new oil seals, races, bearings, paint and general church up. i had debated grinding off the mounting tab and doing a weld on bracket but still on the fence.
Thank you so much that is great help. I will fire that info off and keep you guys posted
Sorry. They are asking me for 2 more measurements. If you could help again greatly appreciated since you have everything apart
another trip to the garage and the large hole on the inside of the drum is 4 13/16
without bearings and races in i can't get the exact spacing from the axle mount to the wheel drum face but would guess its in the area of 3 5/8 give or take 1/4
g
Thank you. I hope it’s not as cold where you are as it is here. -38c ☃️☃️☃️☃️
