Shimmy '49 F4 - Page 3 - Ford Truck Enthusiasts Forums
Shimmy '49 F4
  #31
Old 01-10-2018, 10:42 PM
C600
C600 is offline
C600 is gaining momentum as a positive member of FTE.C600 is gaining momentum as a positive member of FTE.
I must have mis read his post I was under the impression he had very little toe in, my mistake.
  #32
Old 01-11-2018, 12:44 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
I had a similar problem when I first got my truck and replaced the horribly gouged brake drums. After going thru all the things I could think of, it turned out to be that one of the new drums was horribly out of balance. I replaced it and problem gone. I know mine was a fluke but it is another thing that could be checked if you have replaced any of your drums.
  #33
Old 01-11-2018, 08:14 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold49fordv8f4 is a splendid one to behold
Thank you, Jimmy. I have disc brakes on the front with new rotors. I did notice that they did have balance cuts on them when I installed them, but I guess anything is possible. I will keep that in mind if the new tires and adjustments don't cure the problem.
Thanks again, Mark
  #34
Old 01-11-2018, 08:17 PM
49fordv8f4's Avatar
49fordv8f4
C600, Thank you for your replies. I appreciate your input.
Mark
  #35
Old 02-03-2018, 03:55 PM
49fordv8f4's Avatar
49fordv8f4
Update shock mount mock up
Here you can see the wood block to simulate the spring.
The drag link clears the side of the shock by about 1/8".
I will pull the spring apart and clean all the leaves. I will spray all the leaves pretty liberally with dry moly motorcycle chain lube before I reassemble them.
I worked on the shock install for a little while today. The upper mounts are for a '56-'66 F100-F350 and the lowers are from a '71 F600 truck. The shocks are for a 2010 and newer E350. As you can see in the photos, I removed the spring and replaced it with a wood block the same height as the spring. I did this to make sure that the shock doesn't bottom out before the spring is fully collapsed and against the bumper. I have the shock wired almost fully collapsed. I will machine new studs for the bottom mount, as the one that is in there is two bolts tacked together to establish the angle. I will replace the center bolts and u-bolts when I put it back together.
Thanks, Mark
  #36
Old 02-03-2018, 06:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Mark, I don't know that I'd go overboard on lubing the leaves. A lot of the damping was friction between the leaves. My LF spring got coated with 90wt from the steering box and it was like a pogo stick, even with good shocks.
Grinding the top edge of each leaf's end to prevent them digging into the one above is a real good idea tho!
  #37
Old 02-04-2018, 02:43 PM
49fordv8f4's Avatar
49fordv8f4
Thanks, Ross. Maybe I should rethink the lube or maybe just spray a real light coating. I didn't think about bouncing being a problem. When I cleaned up my rear springs, I used my needlescaler to remove the heavy rust then used a wire brush on my angle grinder and a hand belt sander to finish each leaf. I also sanded a bevel on the ends as you suggest. I did spray each leaf heavily with the dry moly before assembly. After seeing how much rust is working out from between the leaves on the spring I removed, I think cleaning the leaves may get rid of the terrible squeak that I have in the front end.
Thanks again, Mark
barfa99
02-25-2012 03:24 PM
Stroke'NPower
04-07-2009 12:28 AM
thenick
1997-2006 Expedition & Navigator
07-21-2005 11:46 AM
greenego
1999 to 2016 Super Duty
09-07-2003 07:00 PM
greenego
08-18-2003 08:36 AM
Quick Reply: Shimmy '49 F4
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
