Flareside advice, wood bed install
#34
#35
And, for the trucks that were higher in the back like mine, the water would sit in the front of the bed. I know that floor wouldn't exactly be water tight, but once all the cracks and crevices would get filled with dirt, it would puddle there, at least a little bit. Mine are in in worse condition up front.
#36
The front panel will be sitting on the metal floor ribs where it will be bolt on the raised ribs and water & crap can go out the lower ribs.
I will have to get a picture next time I have the panel in place as I have the bed taken apart for little more trimming and bottom painting.
Dave - - - -
#37
Wow unobtanium prices indeed...looks like the 70's had the same bedsides??
https://www.ebay.com/itm/NOS-OEM-For...-/142454835373
#39
#41
#42
You'd be selling this as a whole, right?
You wouldn't be willing to break it all down, would you?
Central Mississippi.
Attachment 254419
Attachment 254419
#43
#44
I know this is old, but has anyone found a good looking solution for keeping the bed drained? I'm planning on using stainless hardware and bed strips, but if I just use marine grade plywood and rhino-line it, would that solve problems with water retention and rust? I'm in Florida, so water retention is a concern.
#45
Why use plywood then cover it in bed liner?
If you are thinking water would not get between wood and bed side panels where the bolt up think again.
You also need to seal from the outside, look in at wheel openings and see the side panel and wood meet, that needs to be sealed also or water will get in between at that point.
I have a metal ribbed floor on my flare side and the ribs is lined but not the side panels and when driving in the rain I can see dirt getting it at that point.
Could I seal at the wheel areas? Yes I could but I don't drive it much in the rain if I can help it and I wash the truck often.
Also because of the ribbed floor the front panel dose not sit flush across the floor so water & dirt can be washed out.
Dave ----
Dave ----
The following users liked this post:
