OEM Sound Dampening in Doors
The original ford dampening material in the center of the door shell appears to have been applied with a knife/trowel. Some has chipped off but most is still there and isn't easily removed. Access is difficult above the access panel. How did you guys remove it? Or did you leave it and stick new dampener over it? I plan to clean up the inside where reachable and treat with rust converter then apply dampening material.
Received 4,130 Likes
on
on
None at all, most of it was so brittle it just flaked off. Once I got it off I cleaned the metal with lacquer thinner then used 80 grit paper to etch the metal ,wiped it down again with lacquer thinners and used a small roller and brush to coat it with DOM 16 which is the equivalent to POR15 but half the price..then for sound deadening I used Dynomat..
Bob C. of Indiana
1983 - 2012 Ranger & B-Series
10-23-2014 02:10 PM
Federico1983
04-21-2010 09:26 PM
