Gear ratio for 37’s
Gear ratio for 37’s
on a 2001 f250 7.3 what gear ratio is appropriate for 37” tires? Thinking about 4:30 or 4:56..Im in the mountains with road grades that I have to climb it’s bot too flat here also I don’t drive much on the freeway most I’ll go is 65 for short periods of time.....I’m pretty sure I have 3.73 right now. I noticed a bit more fuel consumption when I got the bigger tires.. any chips that would help at all? All I have on it is the banks six gun. Also I need to swap my trans cooler because I’m noticing the trans temp climbing faster. Seen a lot of people swapping to the 6.0 coolers would be a nice upgrade anyways...
And for the smart&$$’s who are going to leave useless comments like “why would you be so dumb to run 37 inch tires” etc don’t bother.. this is a project I am working on which is why I’m here to finish it... only reason I say that is because it’s happened but this place is from my understanding to gain knowledge and get some help.thanks
I run 4.88's with 37s in a 6.2 gas set up. I love it and think it is perfect. That being said, we have two different animals, the 7.3 turns half the rpms, has 2 less gears, and makes all its torque down low. I think you would be much happier with 4.30's, which would be very similar to a factory small tire truck with 3.55s.
Only reason I’m thinking 4.56 is there are road grades where I live so I would be looking more on the low end two lane road performance rather than a higher freeway friendly gear..
I’ve heard a lot of people with 4.30 but you think that would do ok in the hills as far as getting back close to stock mpg and acceleration??
If it will not climb a decent grade in overdrive with 4.30's and 37's, your either loaded heavy, or your down on power and need to address that. If it was gas, I would totally agree 4.88, but not on a diesel. It should be able to get low in the rpm range and chug along no problem. After all, that is the biggest advantage of a diesel. Your never going to get the mileage back up to factory tires, no matter what gear you run.
I have to either turn my tuner up a couple levels or turn the od off to get up the grade.. it has 3.73 right now and was running 31” tires just recently put 37’s on... in your opinion would 4.30 do good with 37’s on roughly 20 degree climb?
I'm really not sure how to answer that. A 7% grade is the maximum grade allowed on an interstate by law. A new 2018 6.7 is going to somewhat struggle on a 20% grade. If your really hitting stretches of 20% grade for any distance at all on a regular basis, then yes, go low, very low. Or except the fact it is going to down shift.
It's very hard to capture grade through picture or video, but here is a video of 20% grade.
I'm sure that video does not do it justice.
I can't imagine having grades like that and being at speed on a highway trying to use overdrive. I live in the foothills of East Tennessee. I can see the Great Smoky Mountains from my back porch. I can only think of a handful of places that steep around me, and they are all short grades.
People seem to be missing this ^^^ very key point.
4.30s are deep enough. After that you'd be better off looking into power, like larger injectors.
If for some random reason you need to make one certain climb that's 20% with enough weight you can't just climb it normally..... manual hubs and 4Lo works great.
nastruk95
10-30-2004 05:32 PM
ZMCCALL
08-31-2003 11:05 AM
