Crusty Injectors
#61
#62
#63
You could be right, I never really paid much attention to them other than they were available. Maybe use a nylon brush like a toothbrush or something to be sure you are not damaging the cups. Spray the brush with brake cleaner or something before reaching in there to scrub them.
Just putting some ideas out there for you to either use or come up with your own ideas.
#65
on
I've not tried this in an engine and someone might have a reason NOT to do it, but I'll offer this.
1. Biodiesel is a great solvent and shares some chemical chains with WVO
2. Biodiesel has worked fine in my construction equipment. I have not run it in any concentration in my Excursion
3. If you are not *running* the truck, just using BD as a solvent, I don't imagine it would do anything bad.
It was recommended to use a 12 gauge shotgun cleaning wire brush (new) for cleaning the injector holes when replacing cups. I found the "new" copper brush to be very soft- more a factor of "cheap brushes" I think, but that could work in your favor and treat the cups with care?
I'm not sure about the cup sealant and biodiesel?
...and the Elephant in the Room....
Wouldn't it be wise to go ahead and replace your cups while it is apart?
The benefits would be 1) Clean cups and injector holes, 2) New sealant, 3) New cups, and 4) KNOWN procedures and course of action with predictable results.
It's your call, I'm throwing this stuff out there for your consideration and opinions from the collective knowledge trust
#66
Funny you would mention that point...I was going to recommend Methyl Ethyl Ketone (MEK) as a solvent but I'm pretty sure that it is effective at getting loctite off of things when you want to remove it and would not be a good choice in this case.
#67
I did not use any chemicals to loosen the old Loctite. There wasn't any on the upper portion so that was easy. I put a paintbrush handle in the injector hole and used a long, thin screwdriver to chip the old stuff out then vacuumed up the pieces. I used cotton swabs and rubbing alcohol to clean up the seats.
#68
on
I think he was asking about removing the WVO residue and keeping the cups intact. I believe I was the one raising questions about how any solvents would impact the Loctite and suggested considering replacing the cups. Sorry if that created some confusion
#69
#71
Thank you for all the suggestions, and I apologize for the late reply.
I threw everything I had at the residue that accumulated on and and above the cups. I soaked a small thin chunk that I chipped off in MEK, Acetone, Thinner, and finally Easy Off. Nothing touches this stuff.
I have decided to do the wise thing as ExPa suggested, replace the cups, and clean out the bores.
Brian42, did you use the harbor freight kit to brush out your bores? I like the price. I found a nice stainless steel brush kit on Amazon but its $107.99. I'm not sure if we are allowed to link an Amazon product but the is the name of the kit. Diesel Injector-Seat Cleaning Kit (Stainless Steel) IPA 8090S
#72
You can post a link as long as you are not profiting from it. If you are not financially associated with it then you're good to go.
farmert
15
03-15-2014 08:25 AM
