48 F-1 Drip Rail Rust Repair
Thanks JB. I haven't started on the rust yet, but I'll have a look on ebay just in case. I appreciate you input.
Bartman
https://www.ebay.com/itm/1948-to-195...BZLKhh&vxp=mtr
Thanks again.
Bartman
They are all probably going to need a little shaping as they take a beating and are thin. I don't know what they usually go for to know a good price. You might also call rpm motorsports, they part out a lot of truck cabs. Or contact Pat, in Richmond Hill GA. He is on eBay as patrog1. If he doesn't have a set he can probably steer you to someone that does.
JB
JB
JB
JB
Bartman
Just one old man's opinion but I would do what is necessary to stop that rust sooner rather than later. If you can get that truck under cover, get those drip rails dried out and get that flaky paint and rust off you may be able to salvage those drip rails. The more wet cycles they are exposed to, the longer that rust is active, the less chance you have of saving them.
Ray, I agree with you 100%. However, I don't have the room in my shop yet, nor the time to work on the truck. As soon as I do, the rust issue will be dealt with, then the drip rail repaired. Thanks for your input. Us "old guys" have to stick together.
Hey JB, I just had a look on ebay, and you're right, there is a drip rail for sale. However, I think he's asking a bit much. Here's the link:
Thanks again.
Bartman
Thanks again.
Bartman
One thing to keep in mind on the price, it's not just a part out of a box. It involves labor to cut it off, and cut it off correctly so as to not mangle. So the price for any body cut that is a good usable cut is going to be more than what you thought. Just my 0.02......it's my experience in working on these trucks that nothing is going to be cheap if done right and has good looks.
Kevin, it's not a part that I "NEED," it's a part "MAY NEED." I'm not going to shell out money on parts I "MAY NEED." When I get to actually dig into the rust issue and find I can't repair it, THEN I'll buy the used drip rail.
