6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
P0306 & P0278
Old 12-30-2017, 02:07 PM
bluemtn95ford's Avatar
bluemtn95ford
bluemtn95ford is offline
bluemtn95ford is gaining momentum as a positive member of FTE.bluemtn95ford is gaining momentum as a positive member of FTE.
P0306 & P0278
08 F350 6.4 Powerstroke, 174624 on the truck. 46523 on a new motor from Ford installed with DPF & EGR deletes, 4Ē straight pipe exhaust, MiniMaxx tuner, and ARP head studs.
Iíve always done regular maintenance on the dot, Motorcraft oil and filters every 5000, Motorcraft fuel filters every 15000.
Recently sheís started running a little rough off and on. Just a little chugging while at idle. She accelerates and will maintain highway speed and power fine, but at an idle I can sometimes sense a definite roughness. It doesnít always happen sometimes it happens right at start up, sometimes it happens after Iíve been running around all day. And sometimes itíll just go away. Well recently it started and this time the check engine light came on. I pulled over, shut her down, and ran the diagnostics on the MiniMaxx and she threw P0306 & P0278. Cylinder 6 injector misfire and a generic fuel related issue code. I started it back up to find a better place to do some research and both the rough idle and engine light are gone. Is this just crap built up in my injectors or filters? Or am I looking at a new injector? Iím confused because it comes and goes so randomly. Itís been cold here in WA (4-28 F) for a month or so now. I try to run Stanadyne or Power Services winter mix with most tanks.
Thanks in advance
Old 12-31-2017, 09:34 PM
Picton's Avatar
Picton
Picton is offline
Picton is starting off with a positive reputation.
Hopefully one of the more mechanically inclined will chime in here. However, since you run the cleaners which are supposed to help keep all of that system clean and free of crud......may be it is a true injector issue.
I hope not.
JRD761
6.7L Power Stroke Diesel
19
05-28-2017 09:47 AM
fordpride
24
09-10-2011 03:25 PM
Hayes9000
1999 to 2016 Super Duty
06-02-2010 07:36 PM
custom_nirvana
07-23-2009 08:23 PM
Uzumati
19
11-04-2006 08:45 PM
Quick Reply: P0306 & P0278
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
