Finnaly home
  #31
Old 01-01-2018, 01:25 PM
pineconeford's Avatar
pineconeford
pineconeford is offline
pineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant future
Originally Posted by Old51f3 View Post
.... But how easy would it be to change the gear ratio if the driveshaft to something a little more highway friendly ..
If you decide to change the rear end like I did with my F3, a Dana 60 from a '69 to '71 F250 will fit without many modifications. It will require shortening the rear 1/2 of the driveshaft for example and getting a different type of U-joint too.
I was able to get 4:11 gears that way. And parts like brakes, bearings and seals are cheap and easy to find for the Dana.
I considered the stock Timken gear swap but it would have been more money and time than buying a Dana and getting the parts. My total for the nice used Dana came out to about $545 including brand new drums, shoes, hardware, seals, U-joint and such.
I had to make a four hour round trip to find it in a backwoods junkyard up north. The stories I could tell about the junkyard and the banjo-playing guys working there were all part of the excitement and fun of this hobby.
Tom
  #32
Old 01-01-2018, 01:56 PM
Old51f3's Avatar
Old51f3
Old51f3 is offline
Old51f3 is gaining momentum as a positive member of FTE.
Tom
f
Hahaha u can only imagine LOLWhat did you do with the front ?
  #33
Old 01-01-2018, 03:29 PM
pineconeford
So far the front is stock.
Been thinking about setting aside the front drum hub assemblies (that I have re-done) and finding an 8-lug disk conversion.
More time and money though.....
I haven't had it on the road to see how sketchy the front brakes are going to be.
I might regret putting time and parts into the stock set-up like I have.
  #34
Old 01-01-2018, 04:10 PM
49f3dls's Avatar
49f3dls
49f3dls is online now
49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of49f3dls has much to be proud of
Tom TSM MFG has an F3 8 lug disk conversion for 48-50 or 51 trucks. They used my spindle for the mock up a number of years ago. Worked very well on the F3.
  #35
Old 01-02-2018, 04:39 PM
Old51f3's Avatar
Old51f3
Old51f3 is offline
Thank you. I contacted TSM MFG and they are gonna work with me to get a rear disk conversion. Done for me as well . They need some info that Iím gonna start a new forum here
  #36
Old 01-02-2018, 06:18 PM
49f3dls's Avatar
49f3dls
Good people to work with but they don't give you a lot of written instructions on how it goes on.They did ask me for pics so they could make a clear instruction sheet. You may run into the same problem. Don't be shy about calling them for help if you are unsure about the install, they did help when I wante to be positive I did it correctly.
Have fun.
texans
Texas Chapter
17
11-09-2005 12:03 AM
hermangarza
16
01-29-2004 09:06 PM
Opiewan
10-08-2003 03:54 PM
Txquadhunter24
08-01-2003 02:58 PM
Quick Reply: Finnaly home
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
