2000 Excursions won’t start
2000 Excursion V10 4wd. Will crank all day but won’t start. No power at coil when key is on. Fuel inertia switch didn’t move when I pressed it. Battery is good. Fuses in dash all have good continuity. Swapped fuel pump relay with another under hood. Will not start on ether. New battery in key fob. No codes. I’m not certain if I hear fuel pump with key or not. I hear something running for a few seconds but sounds like it’s in dashboard. With no spark, I’m not sure fuel pump will matter at this point. Looking for hints and will keep digging and updating this post as I try more things.
Only have 1 key. I’m quite certain that’s all it came with. 236,241 miles. Completely stock to the best of my knowledge. I bought it almost 2 years ago for parts/maybe a project and it hasn’t left my yard since. I am using it this winter just to pull my other vehicles out of my driveway in case they get stuck in snow.
When you first turn the key to ON, does the check engine light and a bunch of other stuff light up on the dash? The important one is the CEL. If it's not lit, there's no power to the PCM.
Power to the COPs - how did you check it? With the key on, check for +12V between each wire and ground. The +12 feed to the COPs should be red with a green tracer. If there's no +12V there with the key on, there's a very limited amount of things that can go wrong.
Report back with answers to the above.
cbailey1523
1997-2006 Expedition & Navigator
17
12-10-2013 07:05 PM
Monster-4
1999 to 2016 Super Duty
08-29-2013 09:41 PM
