Coolant Flush and Antifreeze Question - Page 2 - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
Old 01-09-2018, 02:02 PM
truckfella's Avatar
truckfella
truckfella is online now
truckfella has a good reputation on FTE.truckfella has a good reputation on FTE.
Originally Posted by 300sflyer View Post
Here's what I did:
Drain the old antifreeze into an empty container"s". Refill with your garden hose. Take it for a 20 min drive. Drain again, then refill one more time with the garden hose, then another 20 min drive. Drain for the last time, and refill with a 50/50 mix of Prestone and distilled water. Most local garages will accept your used antifreeze for proper disposal.
Goes without saying you do not want to do this in sub freezing temps! About zero F here this morning! LOL!
If you do it this way, you're overall final mixture is going to be LESS than 50/50 -- because draining the system does not get all of the water out of the block.
I did what you describe here, but I included 3 additional fills/flushes with distilled water. And at the end of all that, I then added enough fully concentrated coolant (and NOT the 50/50 pre-diluted stuff) such that, in the end, my final mixture is correct.
I did mine in the summer. And I remember it not being fun -- due to the 100'F temps at the time. Doing it this time of year would be even less enjoyable.
parcours
6.4L Power Stroke Diesel
21
11-13-2015 09:10 AM
Studawg
27
04-12-2012 08:24 AM
awq134
2009 - 2014 F150
13
04-09-2012 05:55 AM
DouginTahoe
04-05-2005 07:52 PM
dalfollo
1997-2006 Expedition & Navigator
03-13-2004 05:13 PM
Quick Reply: Coolant Flush and Antifreeze Question
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
