How on earth did he do this.
#46
#47
Now on the same side, they did say that they would deliver it to me at my house, but would not allow me to drive off their lot with anything over my rating hooked to my truck because they did not want any liability of something happened.
At least they were honest and upfront with me. I'm sure there are MANY dealers out there that will just sell a trailer to someone with a truck underrated like this.
But I also believe that someone spending this much money and these mods knew damn well what he was doing.
#48
#49
Back when I had my 07 6.0, we had gone RV shopping (wife and I). Before even understanding all the whole weight ratings that I do now, we were looking for something my F250 was not rated for. The dealer asked for my year, make, model, engine and looked it up on the computer. He stated to me, you can only do X amount and we will not allow you to tow anything more off the lot.
Brett
#50
Don't know how this plays.. F250/F350 SRW have vacuum boost brakes.. F350DRW and F450 have Hydro boost. F250 and F350 SRW/DRW have the same brake size.
#52
When did that start? I thought all 99 and newer Ford diesels had hydro boost, it would be dumb to switch back to a vacuum booster on a diesel.
#53
https://www.fleet.ford.com/truckbbas...ps_-_Specs.pdf
F350 SRW
F350DRW
F450
#54
#56
#57
On a straight stop, it's just braking power. The trailer would be pushing the bed down harder.
#58
I don't believe he was in a turn, from reading comments on the video, it appears he was braking straight and the truck turning over didn't start till he went through the light and got hit in the left side bed of the truck. That turned the truck and started the flip. I would expect the trailer to go over as well though, I just thought it was strange it didn't flip as well. Oh and the comments said they were heading back from Glamis so the TH was probably loaded with toys and fuel for them.
#59
I agree, it changes the balance and therefore the amount of cargo that can be stowed to the rear of the trailer’s axles. As the pin on the fiver is raised the center of gravity moves to the rear. Older tongue pulled trailers can suffer from a phenomenon known as resonance. Trailers with more weight to the rear of the axles would oscillate from side to side (pivoting on the axles), especially under heavy braking, resulting in the tow vehicle rolling. I witnessed this years ago, an old Suburban was towing a mobile home, go figure. That is why in the mid to late 2000’s new tongue pulled travel trailers were designed with the axles farther to the rear.
Fifth wheels do not normally suffer the phenomenon since the forward weight is applied directly over the truck’s axle and the trailer axles are well to the rear. I’m not claiming that excessive weight to the rear of the trailer axles contributed to the truck flipping, I don’t have the engineering skills to compose an accurate calculation. I am just putting forth the scenario that excessive weight to the rear of the axles due to the higher pin connection point (taller tires, lift kit and the ride comfort air bag) caused the tow vehicle to lose control by decreasing it’s rear axle traction. Ineffective braking or loss of lateral control for example.
#60
Those rails are not bolted to the bed of the truck. They are bolted to brackets that are bolted to the frame of the truck. One bed rail was still in place, while the other remained attached to the hitch. A good indication of the forces at work.
It could be interesting to go back and try to identify the rated capacity of the hitch, though I didn't really see any kind of label on it.
I have an older version of the model, mine is 14K GVWR, newer models are 15.5K GVWR
Very easy tp bring them up over 17+ once you start loading them up.
