Misfires and oil leak - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
Old 12-29-2017, 11:54 AM
cmayer cmayer is offline
cmayer is starting off with a positive reputation.
Ex threw a check engine light while towing up a grade and began idling very rough.
P0304, P0305, P0309 = misfires cylinders 4, 5, 9.
Also the PVC valve and driver's side valve cover have oil on them which they didn't before, but even worse is the passenger side from the starter to the bell housing have a ton of oil on them, enough to splatter back all over the transmission, cross members, and even rear axle has splatter marks.
Figure I'll get a new COP and try swapping it with the misfiring cylinders, but any clue as to why it puked oil and could that amount of oil on the passenger side migrated from the PVC?
Originally thought it spat a plug, but they're all still in place.
Thanks!
Old 12-29-2017, 12:07 PM
super 6.8 super 6.8 is offline
super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.
Sounds like your crank case got pressurized some how. Maybe the pcv valve is stuck closed?
Old 12-29-2017, 12:39 PM
R&T Babich R&T Babich is offline
R&T Babich has a very good reputation on FTE.R&T Babich has a very good reputation on FTE.R&T Babich has a very good reputation on FTE.R&T Babich has a very good reputation on FTE.
Quote:
Originally Posted by cmayer View Post
... Figure I'll get a new COP and try swapping it with the misfiring cylinders, ...
With oil all over that's probably causing your misfires.
Cleaning the plug holes and boots might fix the misfiring.
A spare COP is still good to have.
Old 01-08-2018, 10:27 AM
rock2610d's Avatar
rock2610d rock2610d is offline
rock2610d has a great reputation on FTE.rock2610d has a great reputation on FTE.rock2610d has a great reputation on FTE.rock2610d has a great reputation on FTE.rock2610d has a great reputation on FTE.rock2610d has a great reputation on FTE.
Cylinder 9 is on wrong side of motor. It' on drivers side. Is there oil over there?
I think you had a PCV issue which could have blown out a valve cover gasket. But I would think the pcv would have popped out first.
I bet at least 2 plug holes have alot of oil in them. Clean it out and clean cops, put in a new oem pcv and hoses. New plug and oem Denso cop on cylinder 9.
Old Yesterday, 05:49 PM
Thanks, cleaned the oil around the PVC and found the washer around the oil pan drain plug is split and allowing a drip while sitting. I'm assuming that's the cause of the oil on the bottom of the engine.
#9 COP doesn't lock on when plugged in, so when pushed on the idle smooths out a bit. Appears to be the clip on the COP is broke, so ordered a new one and should fix that.
#'s 4 and 5 made no difference whether the COP was plugged in or not, so ordered two new ones with boots and springs.
Using the recommended Denso COPs.
Water in the oil and crankcase pressure? donerico 1973 - 1979 F-100 & Larger F-Series Trucks 15 04-06-2017 05:09 PM
Trying to identify source of oil splatter - underside near rear driver side wheel jbourne84 1968-2013 Full Size Vans 7 06-18-2016 12:28 PM
302 H.O. Swap - Need info on PCV Glaser67 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 05-18-2016 01:17 PM
Green Splatter lcsguthrie 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-08-2016 10:07 PM
PVC and oil breather questions! jasindude1 1961 - 1966 F-100 & Larger F-Series Trucks 9 04-16-2016 05:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
