88' 4.9 I-6 parked 13 years ago, worth saving?
#196
thanks for that Skuzzy. One on the truck is open.
Have an 8.8 in the barn that I will be checking to see if it is a locker. (Good News, it is a locking type!)
Question now is whether to swap whole assbly before doing the rear brakes or just the carrier. Not sure which lash is best of the two if that will make a difference....
Do I understand correctly that the center carrier is the only item required to be swapped in order to make this one a locker ? ?
Was thinking that the entire assembly would need to be exchanged.... please set me straight before I do something dumb !
#197
#198
#200
We Got Tag !
Plus, seems like the lash is much tighter on the 'barn' rear than the original on this truck, so that's good.
There is a difference in the back thickness of the housing, and am not sure how to confirm that it is off of a truck, perhaps the tag will tell.
The outside of the upper housing is missing the electrical sensor that the existing rear has, so not sure what it may be, perhaps speedo.
But here's the pics for interpretation. f
tag
transplant candidate
rear of case is thinner than the existing rear in the truck and there is an electrical 'plug in' missing that the current rear has, maybe a speedo sensor?
this is the existing open rear on the truck
another shot of the current rear in the truck where you can see the 'plug' (electrical)
tag
#201
We Got Tag !
tag
tag
The sensor in the rear is for the RABS (rear anti-lock brake system) .
#202
Thanks My4 on that info. Not sure what is in the truck currently, so will have to take a look inside to see.
Sounds like to retain the RABS system, the gearset will have to have the same ratio and be swapped out, is that correct?
Just got a new hydraulic unit for the RABS so would like to retain it, but that is not mandatory for my intended use, just wanted to totally clean the brake system up and that was the last piece to complete.
Guessing also that this would have been an earlier year than the 88'?
Is the limited slip the same as the 'locker' type diff or is there some difference in the wheel to wheel ratio? Any way the limited slip would be a big improvement over the open diff, right?
appreciate your thoughts
#203
Should look something like this pic from the internet
Looking at the axle tag is ok as long you know the history of the vehicle but taking the cover off and checking is the only way to know for sure what ratio is installed.
Not exaclty. To retain the RABS system you will need an axle equipped with the sensor and tone ring. The gear ratio doesn’t matter other than it will need to be the same ratio as what is in the front diff, if the truck is 4wd.
Maybe it is an early 8.8 rear before they started using ABS so mid 80’s? Before the 8.8 axle was used 1/2T trucks got the 9” and that is definitely not a 9” rear axle.
The factory never ever installed locking differentials. They were either open or limited slip. The limited slip used had clutches so the effectiveness of it after all these years depends on how worn it is. I believe you can get replacement clutches and rebuilt the unit. As to whether you need it or not depends on how you use the truck. Everyday driving on the street is just fine with an open diff.
#204
Gas a good flushing agent?
cleaned up on the outside
check the difference in the i beam lengths! did not realize this.
Here's whats inside of the ibe,am connection. these were totally frozen up could not have been any front to rear movement with the suspension...
ready to go back on soon!
Thanks for the info. The LS is more important for its usage around the farm. Not going to sweat the RABS for now, can always change it back later if desired. Did not know that about the sensor ring! Learn something everyday around here!
Got it cleaned up some and wondering about flushing out the innards. Everyone still just slosh some gas around in there to get the old gear oil out?
Will put some pics up later. Following was inside of the case - E3TV CA , 1340 Ford 6AA ,
Also got the twin I beams loosened up and think that they work much better when freed up. They can articulate now!
#205
#207
Question on replacing the engine control module ??
This truck was originally automatic transmission. Subsequently converted to a four speed.
What should be the priority when replacing the ECM? Should I simply use the existing ECM number from the unit to order a replacement, or would the manual transmission need a different ECM for best overall operation?? Have no idea if the issue was addressed when the transmission was swapped or if it indeed makes any difference to the trucks operation.
Appreciate your more knowledgeable replies as this is wayyyyy over my paygrade .
#208
#209
that door tag is long gone KO, along with the transmission. Is there anywhere else I might look for clues?
Going out to get the ECM out later today and can put its number up if that will provide some insight.....
guess the auto would have been whatever they mated with the 6 cyl. in 1988...
if these are 3.08 gears, it may make a difference...
So the trans may be the biggest underlying variable for the selection for the ECM ?
#210
