Dual tanks for a F350 CC - Ford Truck Enthusiasts Forums
Old 12-28-2017, 06:53 PM
itsnotanova's Avatar
itsnotanova
itsnotanova is offline
itsnotanova is a splendid one to beholditsnotanova is a splendid one to beholditsnotanova is a splendid one to beholditsnotanova is a splendid one to beholditsnotanova is a splendid one to beholditsnotanova is a splendid one to behold
I just bought a 2000 F350 single cab dually and it has the large tank in the rear. I would also like to add the normal tank on it that fits between the frame rails. It should fit in there right?
Old 01-02-2018, 04:09 PM
M-S-G
M-S-G is offline
M-S-G is gaining momentum as a positive member of FTE.M-S-G is gaining momentum as a positive member of FTE.
Your tank is in the rear?
Normal tank goes on the drivers side, mounted to frame.
Excursion tank goes where the spare tires goes.
I think you're asking if you can put a second tank on passenger side frame but you can't unless you chop off and re-route your exhaust.
If you have normal stock tank on the drivers side frame you can add an EX tank where the spare goes but it involves chopping off the crossmember, bed removal and a ton of work.
Old 01-02-2018, 08:30 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
z31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to behold
I have no experience in the matter but you probably could, you would need a fuel tank from a extended cab shortbed or crew cab short bed truck (27 gal), and the transfer valve from an OBS and switch and run some some new wires.
Old 01-03-2018, 05:58 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Sounds like your truck is a chassis cab....those had the fuel tank in the rear. Do you have a bed or utility body? Ford and the aftermarket sells side tanks for tow truck utility bodies because they have to abandon the rear tanks when those trucks are upfitted.
My F450 had two tanks (midship and aft) so I know it's possible. You just need to determine which model will fit based on your trucks configuration. Transfer Flow is one brand that I have used in the past. I couldn't find their website but I did find them for sale here:
Ford Midship Replacement Tank | Transfer Flow
Hope this helps.
Old 01-23-2018, 04:38 AM
itsnotanova
Thanks guys. My truck is a F350 cab and chassis and has a flatbed on it with a rear tank. I found out The CC have narrower frames than the regular F350 . I'm thinking that there may not be enough room for a regular tank inside the middle of a cc frame. Now I'm wondering if there was ever a factory option for dual tanks on a CC? I prefer that option because I might find one in a junkyard somewhere. More than likely I'll have to go with a bed mounted auxiliary tank.
Old 01-23-2018, 04:46 AM
itsnotanova
I did some googling and found that the CC did have a 19 gallon midship tank as an option
Old 01-23-2018, 07:42 AM
Walleye Hunter
Walleye Hunter is online now
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
You say it's got a flatbed on it now, are you sure it's not a chassis cab? The chassis cabs have narrower frames on them and steel tank in the rear.
Tinytune812
12-06-2017 04:32 PM
Duckhunter3688
1999 to 2016 Super Duty
09-15-2017 05:53 PM
Big D-F350
03-10-2017 09:22 AM
Ford_Six
01-21-2017 12:34 PM
LittleRadio
1968-2013 Full Size Vans
04-28-2016 02:11 PM
Quick Reply: Dual tanks for a F350 CC
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
