Basic 390 Timing Setup?
Old Sep 13, 2003 | 12:15 PM
mahanson's Avatar
mahanson
Question Basic 390 Timing Setup?
I just got a 72 F100 Sport Custom with a 390/Edlebrock Intake/Holley 4V setup. I'm trying to track down a backfiring-while-decelerating problem. I'm checking the basics first.
Problem is I'm not familiar with the 390.
Which cylinder is #1?
What is a good timing? I read elsewhere on the forum that 6 degrees BTCD is stock. I also read that 10 degrees is best. I'm running regular unleaded.
Matt
Old Sep 13, 2003 | 12:18 PM
CCampbell's Avatar
CCampbell
I am experiencing the same problem on the 69 F 100 I just bought. Let me know if you have any luck!! I'm not sure where to begin!
Old Sep 13, 2003 | 12:38 PM
DuckRyder's Avatar
DuckRyder
#1 is passenger front.
Timing at 10-12 if it will go that high with no spark knock will probably provide best performance.
A dashpot would help the popping, as would slightly richer mixture in most cases.
Old Sep 13, 2003 | 01:03 PM
mahanson's Avatar
mahanson
Thanks for being there DuckRyder
Matt
Old Sep 13, 2003 | 06:04 PM
Randyb12's Avatar
Randyb12
What is a dashpot?
Old Sep 13, 2003 | 06:12 PM
DuckRyder's Avatar
DuckRyder
http://www.holley.com/HiOctn/ProdLin...MSCA/11-4.html
Basically it is a vacuum diaphragm that mounts to the Carb to slow or “cushion” the throttles return to idle. It minimizes the sudden change in manifold Vacuum and helps with the backfiring. Most mid 70’s on carbureted stuff has one. (manual or automatic)
Old Sep 13, 2003 | 09:44 PM
Randyb12's Avatar
Randyb12
Thanks. Never heard of that before.
Old Sep 14, 2003 | 08:06 AM
lee's Avatar
lee
Matt,
When you say you have a backfire are you talking about 1 large pop, or like my truck did, do you mean that you have many small pops.
Mine would "rumble" when coasting and it turned out to be that the idle was too rich. I adjusted the idle screws in alittle and cured it.
Good luck,
Old Sep 14, 2003 | 08:47 AM
mahanson's Avatar
mahanson
Lee,
It's a chain of pops after letting up on the accelerator. The more under load before letup...the louder the pops. It's not a true carb backfire. I've been tweaking the idle mixture to no effect. My Holley apparantly has no dashpot, so I can't try that idea (unless I can retrofit one...I'm just learning about Holleys).
I did make contact with a previous owner. His theory is that the #1 exhaust valve is burnt. I wonder if that would be a cause for the symptom?
Old Sep 14, 2003 | 08:54 AM
Putt's Avatar
Putt
If you have a vacuum gauge you can check for the burnt valve. The gauge will drop intermittently when the cylinder with the burnt valve operates. The popping could also be a minor exhaust leak. The extra air in the exhaust will burn in the exh manifold causing a pop noise.
