6.0 pcm need vin flash to swap?
on
I would have to say no to the pcm needing flashed. I also have a used one I found at a junkyard from an 06 that I installed just to see if it worked and it did. However I did have codes for abs and other modules because they weren’t matched to the pcm. Check to make sure the pcm fuse isn’t blown.
