Oil leak above oil cooler
The gasket that is between the oil cooler and the oil filter adapter seems to be leaking slightly on the truck in my signature. I have been searching for a replacement seal, but seems you have to buy the whole cooler to get one.
Has anyone had to deal with this and have a solution?
Thanks for any input!
on
I may just replace the cooler. What sucks is I just flushed and replaced the coolant and thermostat less than 3K miles ago. I guess I can find something clean to drain the coolant into and use it again.
I will wait until I need an oil change to do anything to it, but will follow up once I do.
Thanks for the replies!
powerstrokeddiesel
03-23-2008 11:05 AM
