200 amp alternator, enough juice?? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 12-26-2017, 09:36 PM
wizzy214's Avatar
wizzy214 wizzy214 is offline
wizzy214 is starting off with a positive reputation.
Thinking about putting a 200amp alt from a ford excursion, will it fit?
99 e250 5.4l
the mounts look the same am i missing something?
Will it bolt right up is what im asking.
Old 12-26-2017, 11:35 PM
vettex2's Avatar
vettex2 vettex2 is offline
vettex2 has a good reputation on FTE.vettex2 has a good reputation on FTE.
I'd go to an auto parts store and pull 1 of each to confirm it if someone here hasn't done this before
Old 12-30-2017, 12:59 AM
Spaznaut Spaznaut is offline
Spaznaut is starting off with a positive reputation.
You may check if there is an ambulance option alternator for your year van. They are usually 200amp. It also looks like your vans alternator which is the 3G type was changed to 6G in 02' it seems. So only the 2000 and 2001 excursion will have an alternator that would bolt up but they are listed under different numbers for the vans and excursions and I'm not sure what the differences are. Maybe a custom rebuild is your best bet.
Old 01-02-2018, 07:41 PM
wizzy214's Avatar
I bought one remanufatured, sp. On ebay, sent like 20 emails back and fourth rhey said itd fit so i got it at 120 bucks. Ill post pics of the whole process, who doesnt like pics.
Old 01-10-2018, 09:19 AM
So how did this go and was it a 200 amp model?
Old 01-10-2018, 09:39 AM
wizzy214's Avatar
How can i test it?
Old 01-11-2018, 06:03 PM
wizzy214's Avatar
Had it tested at autozone but they want part numbers to match up.
got another store abe electric, they said theyll tell me everything about it. Going there tom.
ill post details.Ok packing i guess.
Old 01-12-2018, 05:08 PM
wizzy214's Avatar
Took it in and had it tested by a good company a.b.e electric, produces 194amps with a smaller pully he said it would do more. Its from a 99 expedition, remanufactured 120 bucks shipped off ebay.
not to bad ill be installing it tom.
Old 01-12-2018, 06:16 PM
Tedster9's Avatar
Tedster9 Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Be sure to get all the juice you paid for, clean the ground points at block and frame etc, to bright shiny metal. Replace those 20 year old cables.
Old 01-12-2018, 06:19 PM
wizzy214's Avatar
Its all getting 4 gauge, grounds and hot.
Old 01-12-2018, 06:20 PM
Tedster9's Avatar
Oorah! That's what I'm talkin about.
Old 01-12-2018, 07:11 PM
wizzy214's Avatar
This lil guy even got 4 gauge
Old 01-14-2018, 08:41 PM
wizzy214's Avatar
Hooked it all up today, 14.45v at idle, about 30 mins drivin home voltage maxes out in the red, got home, 5 mins later and saw some boiled batts, took off, put old one back on. What would make the voltage regulator jump to 18.68volts (voltmeter) had to check.
wtf?Extra 4 gauge to batt.
Old 01-14-2018, 10:52 PM
EagleFreek's Avatar
EagleFreek EagleFreek is offline
EagleFreek is starting off with a positive reputation.
Sounds like the regulator took a dump on your new alternator.
Old 01-14-2018, 11:02 PM
wizzy214's Avatar
Quote:
gee thanks, chevy guy
California Car Cover for Superduty TexasA&M All Other Items for Sale 3 07-08-2017 10:00 PM
2oo Amp Alternator (67D) pack4tag 1999 to 2016 Super Duty 8 03-30-2017 04:00 AM
275 amp alternator Black Ford XLT 1978 - 1996 Big Bronco 7 03-14-2017 02:26 PM
How hard would it be to add another alternator WolfFox 2017+ Super Duty 15 11-01-2016 08:58 AM
1957, 1958, 1959, 1960 Ford hubcaps carbs & chrome Ford Truck Parts for Sale 2 08-13-2016 10:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
