Nitrate or nitrite - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Nitrate or nitrite
Old 12-26-2017, 12:10 PM
Williams65's Avatar
Williams65
Williams65 is offline
Williams65 is starting off with a positive reputation.
Nitrate or nitrite
Just bought coolant test strips from napa to test my nitrate levels and after reading closer it says it tests ph and nitrite levels. I guess i got the wrong strips? Any insight? If so what is nitrite compared to nitrate?
Old 12-27-2017, 08:33 AM
Williams65's Avatar
Williams65
After reading more about it I guess it is the nitrite levels we are after
i went ahead and tested my antifreeze and came up with 1200 ppm nitrite and a ph of about 8.5. So I guess I'm good there but the freeze point was at about 40 to 50 below zero, so I'm thinking it has more than the 50/50 recommended antifreeze to water ratio. Thinking I might drain some and add distilled water. What are you guys thoughts on this? This is a new to me truck about a month ago and am checking and changing fluids and such so I know where I am with them all.
Old 12-27-2017, 10:00 AM
Copper.Farm's Avatar
Copper.Farm
Copper.Farm is offline
Copper.Farm is gaining momentum as a positive member of FTE.Copper.Farm is gaining momentum as a positive member of FTE.
Is this a 6.4L or a 6.7L ?
I know that Ford wants to test the 6.7L motor but i’ve Not seen that on the 6.4L.
Adding distilled water is better than tap water.
Old 12-27-2017, 10:15 AM
Williams65's Avatar
Williams65
My truck is a 2008 6.4. But I can't imagine it hurts to check any of the diesel cooling systems and not knowing very much of the history f this truck as I bought it from a dealer I wanted somewhere to start from
Old 12-27-2017, 03:34 PM
'65Ford
'65Ford is offline
'65Ford is gaining momentum as a positive member of FTE.
Nitrite is a rust inhibitor = good in antifreeze.
Nitrate is an oxidizer = bad in antifreeze. Potassium nitrate is salt peter in black powder.
So you're testing for nitrite.
I'd leave the ratio alone until the next time you flush, and then I'd use distilled water only.
Old 12-27-2017, 03:45 PM
Williams65's Avatar
Williams65
Ok thanks for the info and yes that was my thought to leave it be. I guess there's no concern about there being too much coolant and the mixture being too thick and causing problems???
Old 12-27-2017, 06:02 PM
'65Ford
'65Ford is offline
Going off memory you want at least 30% water.
Old 12-27-2017, 08:10 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is online now
Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.
I went with Final Charge ELC. Don’t have to worry about the test strips like I did with my 7.3.
buickman69
13
07-22-2018 11:29 AM
bubbasz1
06-18-2013 12:35 PM
Gun-Driver
12-10-2009 09:10 PM
guitarpicr
10-25-2007 09:07 AM
deanj
03-14-2005 10:32 PM
Quick Reply: Nitrate or nitrite
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
