6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4L to 7.3L swap
Old 12-26-2017, 08:54 AM
Jeff_Charlton's Avatar
Jeff_Charlton
Jeff_Charlton is offline
6.4L to 7.3L swap
Just curious if anyone here has made this swap. I have an opportunity to purchase an incredibly clean ‘08 F350 Lariat dually for $11k but the owner, huge repair shop owner, says the 6.4L is running bad and they haven’t torn it down. I have a very good 7.3L & trans avail. and I know it would need new crossmember as well as fabricated motor mounts. Any and all thoughts would be appreciated.
Old 12-26-2017, 09:55 AM
DieselDenny's Avatar
DieselDenny
DieselDenny is offline
It would be a project.
But:
If you consider your thoughts of fabbing the cross and mounts.........that's the easy part.
You would also have the aspect of the electronic marriage in terms of harnesses, the fab of driveshaft lengths, the relative cost of the 7.3 and trans, as well as the 11k for the victim.
Is it doable, anything is, is it going to cost alot, absolutely!
The joy of trying to eliminate every warning lamp on the dash would also be a handful.
The availability of parts for the 7.3 in the future is also a consideration. I believe that in the near future, they will be becoming obsolete for alot of components and will near extinction as time goes by.
I have a 99 and 08 super diesel, and it would be a dream come true to have a 2018 7.3 fresh off the showroom floor. But that's not in the cards so like everyone else with a 6.4. All you can do is diligence on maintenance and squeeze your cheeks as tight as you can everytime you roll the key.
If you decide to roll the dice on the conversion, please keep us posted on the results and if you decide to opt out, what prompted you to do so.
It's been kicked around in here before, but I haven't heard of one success story or follow up.
Good luck amigo!!
Denny (you did say any or all thoughts!!! )
Old 12-26-2017, 10:38 AM
Copper.Farm's Avatar
Copper.Farm
Copper.Farm is offline
From a legal perspective, the truck would still be required to meet 2008 emissions.
Old 12-29-2017, 12:14 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
easier to just rebuild the existing engine.
Old 12-29-2017, 11:11 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Someone has already done it:
https://www.ford-trucks.com/forums/1393528-6-4-to-7-3-idi-swap-7.html
Old 12-30-2017, 04:32 PM
lostmybeer's Avatar
lostmybeer
lostmybeer is offline
Have a nice Beer!!!
If Cummins motors are installed, a 7.3 can be done.
Old 07-12-2019, 09:33 AM
nateairman's Avatar
nateairman
nateairman is offline
Bumping this up as my 7.3 runs very good but the truck is falling apart at +450000km
Old 07-12-2019, 09:00 PM
97-psd's Avatar
97-psd
97-psd is offline
Man, that IDI thread was incredible. It looks like a well built turbo IDI would be a better solution unless you are pretty good with electrical troubleshooting. Personally, 11k would be too much to pay for a truck with known Problems. If you commit to it, please document your journey. I am sure others would benefit from seeing how you make it work.
Old 07-12-2019, 11:43 PM
nateairman's Avatar
nateairman
Just kicking the thought around as a f450 king ranch came up that I could afford until then first check engine light. The IDI was a pretty good read though! I think a DI could be done pretty good too. I just dont think it would compare to a good running 6.4 but I have no real experience with 6.4s
Old 02-19-2020, 06:57 AM
Adam7.3l/08's Avatar
Adam7.3l/08
Adam7.3l/08 is offline
Working on the exact thing will keep posted on harness mods. Will try to keep detailed descriptions.
The start of making 99 7.3l talk with 08 6.4l body
Old 02-19-2020, 07:01 AM
Adam7.3l/08
Anything is possible
Old 04-08-2020, 07:55 PM
Jk01/08's Avatar
Jk01/08
Jk01/08 is offline
Originally Posted by Adam7.3l/08
I’m looking to put my 01 7.3 zf6 in a 08 f350 with a blown 6.4. I’m interested in how ur making out with this project and what u have done so far. Did u put ur motor in the 08 frame or put the cab on ur 99? I was originally thinking about just putting my 01 harness in but the 08 is a 4 door lariat with some bells an whistles I’d like to keep but not exactly sure how I’d get it all to work.
Old 04-15-2021, 11:25 AM
Magnonc's Avatar
Magnonc
Magnonc is offline
Were you able to get it to work? Any updates?
Old 10-06-2021, 08:44 PM
87f150xlt's Avatar
87f150xlt
87f150xlt is offline
That looks real good. Looks like the IDM is already mounted at 7.3 location. Where did you mount the ECM? We would love to get more info on your swap!
Old 10-06-2021, 08:52 PM
87f150xlt's Avatar
87f150xlt
I wish Adam7.3l/08 could post up detailed updates!
Quick Reply: 6.4L to 7.3L swap
