What brand differential/axle parts?
That's what I'm going to do this go-round, I can see the wear pattern on my axles, but can't feel or measure any wear. But then again, one axle is only a couple years old, the other about 6 yrs on it, with around 30K on it.
Thanks so much for the help NumberDummy!
I guess the most critical question right now is, did I order the correct axle shaft for the left side?
Unless the seller ships it out tomorrow, I can still cancel the order,, I think..
Saturday I negotiated a price with a Ebay seller and bought a Ford OEM axle part number
Brand: Ford
MPN NUMBER: F7UZ 4234-BB, YC2Z-4234-CB
“The parts list you posted shows the correct part number for the left axle to be F7UZ-4234-E”
Where did I get the YC2Z-4234-CB from?
FordPartsGiant shows,,
Part No. E7UZ-4234-E
Replaced By YC2Z-4234-CB
https://www.fordpartsgiant.com/parts...ear-axle,,4234
Rock Auto shows part # YC2Z-4234-CB
http://www.rockauto.com/en/catalog/f...le+shaft,10439
BUT NOW Amazon lists a Dorman axle listing the original part numbers as
E7UZ 4234-E, F7UZ 4234-BB, YC2Z-4234-CB and saya it does not fit my 88 econoline!
So does part number E7UZ 4234-E also update to F7UZ 4234-BB, YC2Z-4234-CB?
I will make another post about the spider/side gears in a bit..
Thanks
Anna
Brand: Ford
Thanks
Anna
Would you attempt this with the axle still under the van or would it be much better to pull the axle out from under the van? I really need to put some new springs and shackles under the van but didn't want to spend the money right now. Last year I rebuilt the front end and started to drop the rear axle to replace the leaf spring bushings but it turned out that the springs were not stock and so the bushings I ordered wold not fit. I wound up just putting it back together and new shocks.
Ok when it comes to the spider gears..
Motive Gear sells a complete kit with all 4 gears, the pin, and bolt for $80.00 but only carries a 50k warranty
But I am pretty sure I can buy the Ford OEM parts for the same or less.. So
Here is a list of the rest of the parts I will need.
1- D8BZ-4241-B, Differential pinion shaft lock pin (bolt) Replaced by D8BZ-4241-C??
2- C7AZ-4A332-A, Axle shaft O-Ring Replaced By E9AZ-4A332-A??
1- E7TZ-4236-A, Gear Kit (Differential side) W/Washers
This kit is not on the parts list you posted. It is the 2 gears that slide on the cross pin.
There is no kit or gear part number on the list for these gears.
1- E7TZ-4215-A Pinion kit/ 8.8 includes 2 pinion gears with thrust washers???
https://www.ebay.com/itm/OEM-Ford-8-80-Differential-Side-Gear-Kit-E7TZ4215A-For-Various-00-02-F150-E150-/401376857120?_trksid=p2349526.m4383.l4275.c10
The cross pin is not listed on your list either.
1- E7TZ-4211-A Cross Pin ???
I found a set on side gears on Ebay for $27.00 Part # E7TZ-4236-A One of them appears to have just a little surface rust on one edge but I dont think it is a surface or enough to make any difference. They should clean right up.
https://www.ebay.com/itm/FORD-RR-AXL...4383.l4275.c10
autonationfordwhitebearlake.com online Ford truck parts catalog lists YC2Z-4234-CB left side for your 1988 E150.
MSRP: $341.95 ~ Auto Nations online price: $225.69.
The right side is YC2Z-4234-CA - MSRP: $317.23 ~ Auto Nations online price: $209.37.
Auto Nation (formerly Tousley) Ford in White Bear Lake MN online prices are dealer net cost + 10%
As far as I am going into this rebuild it is a shame not to go ahead and change the gears out to the 4.10s you recommend but being the first time I have done this it might be better if I just stick with the originals for now. If it all turns out well then I will attempt it later and have some experience.
As getting the pinion depth set and back lash on the gears is largely a trial and error method, it's easier to pull the whole rearend to do both. As for getting the correct axles, what you need to do to ensure you get the right parts is to pull them first and measure them both before buying axles that you're not sure of. This is what I did before buying my axles from Summit Racing. They list the lengths of the axles they sell so that you're assured of getting the right parts. Pulling the whole rear isn't that bad a job, as it's bolted on under the springs, I did mine by myself. Only thing you need to be certain of is having the van positively supported before doing the job. I've got two sets of jack stands under the springs forward of the rear and another two supporting the rear under the class 3 hitch.
Today I ordered the spider gears and the cross pin from a Ford dealer that I have dealt with before. The spider gears come in a kit with all 4 gears, thrust washers, and locking bolt. The kit was $83.00. The cross pin was a little higher then online but still ok at $14.00.
The dealer is 50 miles away so depending on how much they charge me for shipping, I may drive up there and pick the parts up.
You mentioned the differential case might be worn also. I found a new OEM Ford case for $100.00 with free shipping. Surprisingly the ford dealer only wanted $125 plus shipping for it. I haven't ordered it yet because I just hate to let go of another $100.00 but I am into it this far!
That leaves just the right side axle and a ring and pinion set!
Since I already have the Ford axle on the way, I am thinking about the right axle from Motive Gear. they have a line called Ten Factory which carries a 10 year warranty or 100k miles. Summit carries them so I can pick it up after I have removed the original one from the van.
The Ten Factory axles are sold as a performance axle. I read somewhere along the line that some of the performance parts are not designed for street use. Something about the steel they are made of or that the tempering is designed to give a little under stress so that they don't snap and so do not hold up well for street use. Have you ever heard something like that? That Ten Factory axle is around $150.00 Motive Gears standard axle is around $75.00.. Whats your thoughts?
Ok as to removing the axle...
What about dropping it with the springs still attached?
I think I already posted that last year I was going to replace the shackles and bushings but had thew wrong bushings. If I drop the axle with the springs still attached I can change out the bushings and shackles while I am a it. I have all the bolts already, they were correct.. I know that would make it a bit harder to work with but I have some saw horses I could set it up on and that would actually help by raising it up higher for working on.
Thinking it would probably be a good idea to change the flexible brake line hose as it is original and I will have to bleed the brake anyway. I already replaced the front ones and the rear wheel cylinders last year.
Oh I hope I didn't make a mistake here too, but I ordered a used 1/4 dial type torque wrench that reads up to 30inch lbs from Ebay for $36. The seller has 100% feedback and says it works as it should.
CDI Dial Torque Wrench Model 301LDIN
I already have a 1/2 and 3/8 click type and don't know when I will ever use the 1/4 again..
I know with the larger torque wrenches they say not to use adapters or extensions but at less then 30inch lbs I would think it wont make much difference?
Oh as to stands, bought a set of those 6 ton stands from HF last year when we did the front end rebuild. The only others I have are 3 ton standard stands. My 85 van has a (don't know the rating) heavy hitch on it and I have been intending to swap it over to my 88. I would guess there shouldn't be any difference and so it should bolt right up to the 88?
I hear you on the axle tempering. Seems back when I replaced both 6 years ago, both axles ordered were Yukons and one failed after a few years, wasn't properly hardened at the bearing surface. I'd have to go back and look in my acct on Summit to see for sure. Seems everything you buy now is a crap shoot as to quality. The replacement is a so called "performance" brand (again, don't recall for sure as to that, but it's got a decal on the end attesting to that) Dropping the axle with the springs attached would be a bear with the extra added weight. Ask me and I'd advise you to pull them separately, you only have the U bolts to unbolt to boot. To me it would make your job easier to do it this way, both in removing it and putting it back in.
Ok, tried to go back on Summit and look but their order history for my acct doesn't go back far enough. I may be wrong on Yukon, it may have been some other mfg. I do recall though one axle was on sale or clearance so it may have been another mfg than Yukon. If I had the time and inclination, I'd have both ends of the housing changed to 9" style and get rid of both the C clip retention and the axles serving as the inner bearings. I did that with an 8.8 out of an Explorer when I swapped it into an 89 Ranger.
No, the nuts should be fine as long as you lube them and clean the threads before removing them. Wire brush the threads and oil em up with ordinary cookin oil before taking them loose. Cookin oil works better than WD40 for this. We unbolted a pair of 90 year old railroad switch stands a few years back using peanut oil as a lubricant. Once we broke em loose they unscrewed like they were new.
#29
They are both MarkIII vans though so I even have a spare high top if needed!
#30
Thanks for the tip on the peanut oil too, I have never thought of that..
My dad was a mechanic and machinist and I always liked working with him so I learned a good bit from him.. Except how to read non- digital micrometers which I might need to use for this job!
