Best tow mirrors? - Page 3 - Ford Truck Enthusiasts Forums
Best tow mirrors?
  #31
Old 02-13-2018, 05:34 PM
Sous's Avatar
Sous
Sous is online now
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
Bought these mirrors on Ebay for $127 shipped to the house. They needed a slight bit of trimming on the back of the plastic, but the second one took 10 seconds after I figured it out on the first one. They are manual fold, power heat, power adjust on primary mirror, manual adjust on lower mirror and smoked turn signal.
Very happy with their coverage and look forward to using them this camping season when the 5th wheel is following me around the country.
  #32
Old 02-13-2018, 06:14 PM
Whitey Ford's Avatar
Whitey Ford
Whitey Ford is offline
FTE-Spread The Knowledge
Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.
Looks great! They sure let you see more.
  #33
Old 02-14-2018, 09:26 AM
brandon_oma#692's Avatar
brandon_oma#692
brandon_oma#692 is offline
brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.
What brand? Looks good and nice value. Did you have to cut off a pin/nub/bump that hit the door? If so that is the same as I did with the newer ford takeoff ones. I assume the newer doors have another hole that it goes in. If not well never mind...
  #34
Old 02-14-2018, 09:39 AM
Sous's Avatar
Sous
Sous is online now
Brand is China special I am sure, but I bought them from an Ebay seller named "ledkingdom-us" based on a review that afmedic had done with the same mirrors.
https://www.ebay.com/itm/for-99-07-F...72.m2749.l2649
Yes, there was a nub near the top corner bit that needed to be removed, then I shaved off about 1/4" of a lower bit as well just to be sure. They fit and look great with 30 seconds worth of modifications.
Debating on tossing my old mirrors out or putting them in the free parts section.
  #35
Old 02-14-2018, 10:58 AM
brandon_oma#692
lol I am in the same boat with old parts. I am hanging on in case I get another truck. The stock mirrors sitting on the shelf would replace the little ones if it comes with them in a heartbeat. I need to list some stuff for sale with more to come after I install the turbo. I just do not want to ship. Hope to find someone close enough that wants the stuff even if I could get more shipping it. Or just let it sit in the garage rafters.
  #36
Old 02-14-2018, 01:13 PM
brian42's Avatar
brian42
brian42 is offline
brian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant future
You never know what it will come in handy. Just put the Racor on my truck and used the plastic loom from my old HPOP hoses to provide some extra protection for the fuel line between the Racor and fuel pump. They are a perfect fit. I've been meaning to throw those hoses away for the last 2 years. Glad I didn't.
  #37
Old 02-14-2018, 01:49 PM
F250_'s Avatar
F250_
F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
I like the look of those smoked marker lenses, Sous.
  #38
Old 02-14-2018, 01:52 PM
Sous's Avatar
Sous
Sous is online now
Thanks, I never intend to hook up the turn signals to the mirror, so a smoked signal was a no brainer for me. I had looked for power adjusting without the turn signal (smoked or amber) and could not find any. There were plenty of manual adjust, non-turn signal, but I like having the power adjustment.
I think they look good and they are a 100% improvement over the curved OEM mirrors. I have not had the chance to drive with them yet, but will here in a few more days. I will report back with glass vibration or lack there of and opinion on how they perform on the road with the 5th wheel in tow.
  #39
Old 02-14-2018, 02:14 PM
afmedic
afmedic is offline
afmedic has a good reputation on FTE.afmedic has a good reputation on FTE.afmedic has a good reputation on FTE.
Mine are still going strong. Truck vibrates like a SOB with my cupped tires, but the mirrors are still nice and clear! I still need to hook up the lights. I'm planning on using them for marker only
  #40
Old 02-14-2018, 03:11 PM
00Dave's Avatar
00Dave
00Dave is offline
00Dave has a good reputation on FTE.00Dave has a good reputation on FTE.
Hey Sous, I am just guessing but I'm betting they weren't plug and done? Had to change the wiring a bit?
  #41
Old 02-14-2018, 03:14 PM
afmedic
afmedic is offline
If you already have power mirrors they are plug and play. They have the later model rectangular connector. They come with an adapter to connect to the earlier round mirror connectors if you have one of those too. If you don't have heat and turn signal on your existing mirrors you'll have to run wires for those, but power mirror functionality is plug and play.
  #42
Old 02-14-2018, 03:34 PM
00Dave's Avatar
00Dave
00Dave is offline
Thanks! I'd say I would need the adapter since mine is a 2000.
  #43
Old 02-14-2018, 03:35 PM
afmedic
afmedic is offline
Yes probably. They come with it, which was nice. They aren't oem connectors so the fit is kind of tight, but they work well and latch securely.
  #44
Old 02-14-2018, 03:37 PM
F250_'s Avatar
F250_
F250_ is offline
Is anyone aware of any vendor selling the adapters separately? I snagged my 2012 mirrors before all the after market guys started supplying them with the adapter options. I'd rather not be cutting and splicing if I can avoid it.
  #45
Old 02-14-2018, 03:38 PM
afmedic
afmedic is offline
Quick Reply: Best tow mirrors?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
