fuel pressure question
Old Dec 24, 2017 | 09:59 PM
justcruzin125's Avatar
justcruzin125
So how long should a fully primed fuel system at 35psi drain down to lets say 25psi. Im asking because ive been chasing a hard hot start issue on my 1990 f250 460 for awhile now. No codes popped up for this problem so i doubt its anything electrical. Used my fuel pressure gauge and it took 40 minutes to achieve a 35psi to 25psi reading. That seems way too quick. Im thinking maybe the injectors are leaking fuel into the cylinder(s). Sometimes it takes a couple trys to start the truck when its warm but starts instantaneously when its cold. What do you all think? It also has a new fuel pressure regulator
Old Dec 24, 2017 | 10:55 PM
ChRoNo16's Avatar
ChRoNo16
If the system is good, It should not leak pressure at all.
I think either injectors or pressure regulator
Old Dec 24, 2017 | 10:58 PM
wtroger's Avatar
wtroger
No that’s not bad. A quick way to trouble shoot that is to cycle the key a couple of times before trying to start. If you do this and it fires right off then yes there a fuel delivery issue. It it doesn’t change anything then start hunting something else.
Old Dec 24, 2017 | 11:01 PM
justcruzin125
I dont think its the fpr since its new and theres no gas in the vacuum line on top of the regulator. Is it possible for the pressurized fuel to leak back in the tank? Kind of doubt that since it is hard to start when hot. Kind of leaning towards the injectors
Old Dec 24, 2017 | 11:15 PM
wtroger's Avatar
wtroger
It usually does lose pressure back to the tank. I have yet to find a fuel system that had any fuel pressure after it has set over night. When it starts is it flooded. Heat soaked coils and distributor pips can and do cause this problem. Usually a leaking injector effects only one cylinder causing a short term miss.
NotEnoughTrucks2014
13
May 6, 2018 11:30 AM
GummyF250
Jan 17, 2010 06:45 AM
FirstFord89
Nov 10, 2009 01:33 PM
tgore3
45
Jul 21, 2009 12:02 PM
sport1100
1983 - 2012 Ranger & B-Series
Aug 26, 2006 08:48 AM
