2008 6.4 l turbo diesel idle? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 12-22-2017, 08:29 AM
SpectrumEquine
SpectrumEquine is offline
SpectrumEquine is starting off with a positive reputation.
Where is the idle adjustment on a 2008 6.4 l turbo diesel?
Old 12-22-2017, 08:56 AM
DieselDenny
DieselDenny is offline
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Why do you ask?
Tell us a story. How high is it running and are you deleted, etc...
Denny
Old 12-22-2017, 09:26 AM
Copper.Farm's Avatar
Copper.Farm
Copper.Farm is offline
Copper.Farm is gaining momentum as a positive member of FTE.Copper.Farm is gaining momentum as a positive member of FTE.
I don’t think there is one as everything is fly-by-wire controlled by computer.
Old 12-22-2017, 09:30 AM
SpectrumEquine
From what i can see it has the EGR deleted. It is running 950 to 1000 rpm.
Old 12-22-2017, 11:12 AM
00t444e's Avatar
00t444e
00t444e is offline
00t444e is gaining momentum as a positive member of FTE.00t444e is gaining momentum as a positive member of FTE.
Idle speed is computer controlled.
Old 12-22-2017, 03:12 PM
DieselDenny
Spec,
When I bought my truck 08, it was allready dpf deleted. It idled at 950-1000 and it was unmanageable in parking lots etc.
When I researched the cause it all came down to the sensors/probes in the exhaust.
I crawled around and found that I was missing the furthest back probe.
I bought and installed it into the harness where the connector was empty and my idle dropped to 600-625. All good.
Is your dpf removed?? This could be your problem regardless.
Denny
Old 12-22-2017, 06:29 PM
Copper.Farm
Computer controlled and influenced by tune - some tuners had high idles.
Old 12-27-2017, 07:40 AM
SpectrumEquine
What is a few of the best tuners out there for the 6.4 diesel? I did not get a tuner when i bought this truck used and there is probably no way to tell which tuner was used is there?
Old 12-27-2017, 09:29 AM
Copper.Farm
I have a Mini Maxx and i’m Pleased with it.
- connect the first time to select make and model
- connect the second time to program
- put it back in the box
logan_85
126
01-19-2014 01:00 PM
jtcf250
57
04-29-2009 12:13 PM
jcbx
1968-2013 Full Size Vans
03-23-2008 12:13 PM
Roger Ripspeed
Engine Swaps
06-19-2007 10:34 PM
Fourwheelinj1
10-13-2004 07:54 AM
Quick Reply: 2008 6.4 l turbo diesel idle?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
