Steering wheel shaking around 60 to 70 MPH
Old 12-19-2017, 04:59 PM
kwizman's Avatar
kwizman
kwizman is offline
I've got a shake in the steering wheel of my 2007 F150 CC 4x4. Its noticeable at 60 MPH and bad at 70. I was under it yesterday and had my dad turn the wheel back and forth. There is a slight clicking noise coming from the ends of my steering rack. Is that normal? Would that be a sign of the inside tie rod connection wearing out or the rack and pinion going bad? Just looking for some experience with this, I hate throwing money and time at it just to not get any further along.
Thanks
Nic
Old 12-19-2017, 07:51 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
I would think it would have more to do with wheel balance and alignment than the rack and pinion setup.... do you see any significant tire wear on the edges ? How long has it been since tires were balanced and align ?
I had a similar problem with my 2002 and checked EVERYTHING... I could feel it at 60-70 MPH, but not "bad" ............ ended up being the rear drive shaft U-joint dry and bearing starting to spall.
Old 12-21-2017, 07:48 AM
1saxman's Avatar
1saxman
1saxman is offline
99% of the time the problem is wheel/tire-related. Balance, tire belt separation, bent wheel, etc. Alignment almost never causes wheel hop.
EXv10
11-05-2021 11:09 AM
chips34
08-17-2017 11:13 AM
Midnightride42
1997 - 2003 F150
06-09-2012 12:16 AM
dmeyer 351 4x4 rebel
08-18-2010 06:31 PM
gt5-33
04-15-2009 08:27 PM
Quick Reply: Steering wheel shaking around 60 to 70 MPH
