Graphing my new injectors...analysis?
#31
on
I REALLY want to keep the EBPV system. I often drive a few miles in 1st gear (4R100) to warm up in the winter. Even with the system, it takes quite a while to warm up the engine and then get heat in the cabin up here on cold days.
Thank you!
#33
on
Findings:
EBP Sensor tube with sensor removed
The partially clogged EBP Sensor
Tip: Holding your finger next to the item you want to have in focus from your camera helps.
So I'll be removing my (NEW this past Spring) EBP tube and cleaning both the tube and sensor and *hopefully* that will solve the issues
At least let me move onto the next step of tweaking. I'd much rather be tweaking tunes and stuff than repairing
Thank you to Sous and Mark for their kind and generous offers of EBPV solenoids. With the above findings, I don't think I'll need one. I REALLY appreciate it, guys!
#34
#35
on
I have a single "Economy" tune from Tony Wildman. Once everything is worked out and we tweak anything that needs it, I plan to get tow and performance tunes, too
#39
#40
#41
In Torque Pro, my "boost" reading from the MAP will only go to 24.8 psi. With my new turbo wheel and non-leaking up pipes, I'm hitting 30 psi on my manual gauge. And I've noticed that my MAP reading on Torque Pro will be messed up until the SES light from the overboost code clears. It actually shows a high reading equivalent to the overboost. For example, If I hit 30 psi on my manual gauge, the MAP reading will read approximately 5 psi high until the SES light clears. Then everything resets. Not sure if others have this problem, but that's how things are working with my PHP tunes. When I first did this, I thought I messed up my MAP sensor. But so far, it has reset every time. I know it probably isn't good for the sensor, that's why the Riff Raff overboost controller is soon to be installed.
#42
#43
on
I have a few places with spotty traffic and wide open space. I wait until no traffic and go for it.
In this thread I have been logging and then picking out the section of data that appears to be of diagnostic value.
#45
on
Wrinkle:
After painstakingly cleaning the EBP tube, sensor, and front mounted fitting, I was initially pleased as before. While temp is low, can give burst of throttle and turbo jumps up quickly. Easily hits 25psi.
After warming up and holding the psi a few seconds, it drops. Then the idle is crap.
I pulled over and listened for the EBPV being closed, but no jet engine sound as I've become accustomed to over the years. I climbed up on the truck before after the run and the EBPV lever appears to be in the correct position. There really is no access to the lever without removing the CAC tubes and spider
I tried unplugging the ICP sensor after returning from the aborted run (only made it half way to the site, turned around), but no improvement.
I wiggled the passenger side UVCH plug while running, no difference (carefully suspended over top using the topside creeper and all strings and parts tucked in and away from the belt )
But I noticed FIPW (Fuel Injector Pulse Width) jumping around erratically while idling and decided to grab a log of it.
Here it is:
Notice how the ICP is dead steady? It does vary a little but not in this sampling.
The lime green is FIPW. See it jumping around and notice the RPMs in orange.
Ideas?
Another bad injector? Bad UVCH?
Since it is idling, even a bad turbo or EBPV wouldn't cause this, right?
Fuel pressure is 85-90psi and steady. I do have aftermarket fuel filter right now, Purolator I think, with the integrated cap and filter.
Still starts in before the end of "One Mississippi"
I'm thinking about putting a new UVCH on the passenger side. I don't have orings to reinstall the turbo so I am avoiding pulling it until I can't.
Here it is:
Ideas?
