Fuel pump question
Well I changed the pump bc I my truck wasn’t starting and had narrowed it down to that but when I opened my tank up the line from the pump to the cap had just come off bc the guy used too big of line and didn’t even have the clamp on the right place and I had already bought the new pump so I figured I may as well use it, but I might switch it back today
Voltage rating of fuel pumps?
My 48 gph pump is rated at 12vdc.
I probably see 13 VDC so it' pushing more than 48 gph. Probably closer to 52 gph.
If yours is rated at 12vdc you are pushing more than 60 gph.
I am not sure at what point the stock fpr will over run but I suspect your new pump is not working right.
I'm not really sure....I assume the fpr regulates the pressure. Unless the pump is so big it over runs the fpr. In that case I guess pressure and flow go up.
So, pressures are regulated via fpr. If fpr is too small it will be over run and pressure will increase.
flow is kinda irrelevant if fpr can do its job, on my return style system anyhow. Any flow not used goes back to tank....
Saying this IMPLIES the return line is not the limiting issue. It should be capable of returnng all fuel the motor does not need, without increasing fuel pressure do to being too small.
I assume the pressure between tank and fuel pressure regulator is higher with a bigger pump and flow past fpr is more ........up until the fpr is over run.
