Wire led light bar to factory fog lights
I’ve got a 2006 f150 stx it has the pull out fog light switch but doesn’t have the fog light bumper I was wondering if anyone has wired a light bar to this switch. Is there a harness already in there or do I need to run a wire all the way through? How many amps can I pull?
+1 on what P.Bronner Said. Fog light wires should be there, especially since you already have the switch. Check near the frame and the front bumper where the fogs would be on both sides, but I'd guess driver side. I'll check mine later tonight and give you a 100% answer.
Fogs will come on with parking lights and low beams when the switch is pulled out.
In regards to the low beam/high beam, most states it is illegal to run a second set of lights with your high beams unless it is the low beam lights. Also, in most states it's illegal to mount your fog lights above you head lights UNLESS they're amber. Also, check and make sure your LED's are DOT approved for on-road use and DO NOT say off-road use only. It sounds redundant, but it needs to be said.
Now is it enforced? Not really. But you find that one dick who's having a bad day...
