Rear fender question
on
That would be my handy work Pete. This chart is taken from a 53-56 bedside...I am not sure how/if that translates to an F1. The OP has not mentioned whether his bed has fender mounting holes in it...if it does then the fender hole location becomes a bit easier.
What I did on mine was mount the fenders where they need to be to match up with the running boards and clamp them to the bed (I used vice grips) and running boards. Then when you are sure the fenders are where you want them drill the holes from inside the bed into the fender flange.
That is what I did when I moved my fenders. I first cleaned up the area then painted it with rattle can light gray primer. Then clamped the fenders where I wanted them then marked the holes with a Sharpie.
John Morton
08-01-2015 07:44 PM
arrowheadfred
10-30-2010 02:29 PM
Fighter-of-Wars
10-22-2009 11:01 AM
GreatNorthWoods
25
09-21-2006 06:03 AM
