Are 360 cams factory retarded? - Ford Truck Enthusiasts Forums
Old 12-17-2017, 08:49 PM
bigreed91 bigreed91 is offline
bigreed91 is starting off with a positive reputation.
Hey guys, as the title states, are 360 factory cams retarded? My wife got me a gasket set and a timing set as it jumped time 2 years ago and has sat since. So for right now the motor isn't coming out, just gonna do an in frame to kinda freshen it up, to get it back in a running state so time can be spent elsewhere like floor pans. Anyways i have the edelbrock 7808 with 3 keyways (4retarded, stock, 4advanced). Some of my research says to advance it as i'd rather have low rpm torque rather than high rpm h.p. I know i should swap out the cam or make it a 390 but that ain't the goal for now. It does already have edelbrock intake and a quadrajet on top and i'm hopeing i can squeeze a set of headers into this job. What's yalls input?
Old 12-17-2017, 09:59 PM
Sorry, forgot the basics: 1976 F100 360, AT, 2WD, single cab short bed.
Old 12-18-2017, 11:13 AM
KO1960 KO1960 is offline
KO1960 is starting off with a positive reputation.
The only sure way to know is to degree the cam.
Old 12-18-2017, 11:27 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Put it straight-up. The 1972-up 360's had a different timing set - the retard/advance was done in the (I think) cam gear. The cam itself is "normal". So if you're putting an aftermarket timing set on it, "straight-up" will be pre-1972 cam timing.
Bend any valves?
Old 12-18-2017, 11:42 AM
Don't know yet on any bent valves, i hope not though. The heads are coming off anyways to do head gaskets so everything will be looked at. I'm gonna pull the truck up to the house this week and hopeing to atleast get the radiator pulled out.
Old 01-21-2018, 04:59 PM
Update: yesterday pulled the fan and radiator, today pulled the fuel pump, alternator, and water pump. Then i pulled rhe valve covers...driver side looked fine, passenger side not so much. The rocker shaft broke on the front side of the second pedestal. The front pexestal bolt was out and not broke. I'm thinking front bolt backed out putting too much pressure on the shaft at the next pedestal causing it to snap.
Old 01-21-2018, 06:15 PM
Krewat's Avatar
dang. how's the head surface where the pedestal was?
Old 01-21-2018, 07:11 PM
Not sure yet, to nasty to tell. Heads coming off to do head gaskets so i'm gonna get it cleaned up. Hopefully it didn't move around so much that it took metal off. Rocker shaft from auto zone is only $26 unless i find someone giving some away.
Old 01-22-2018, 07:58 AM
69cj's Avatar
69cj 69cj is offline
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
If the heads don't have hardened valve seats nows the time to do them.
Power options for a 400? DJSTRAIT21 1973 - 1979 F-100 & Larger F-Series Trucks 19 02-03-2018 10:07 AM
Cam Retarded Redwood2279 2004 - 2008 F150 3 02-02-2018 11:29 AM
78 400 Timing chain help. stroken7.3 1973 - 1979 F-100 & Larger F-Series Trucks 12 01-31-2018 06:10 PM
Timing Chain Identification Martin Torres FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 05-20-2017 10:41 PM
"Zero retard" cam sprocket farmpaw 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 20 03-20-2016 07:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
