putting an AOD behind my flathead!
I did an advanced search and found very little about the various adapter kits.
I like the idea of the Speedway kit-seems well thought out.
Here is the link for the one when you have your own trans:
https://www.speedwaymotors.com/Flath...Kit,11051.html
Has anyone have experience with this? I love the five speed idea, but as this is the first project my wife has had any interest in being part of-well she wants to be able to drive it and manual transmissions are hard on her....
I am going to go with a 3.7 to 3.9 rear diff in a 9" Ford out of a 70 F150. From the calculations that should make the combo very happy for the old flathead (when fitted with a small four barrel to drive the TV cable)
Any thoughts or ideas?
Thanks to cougar54 for the link to a great cross member kit! My frame was missing the original cross member that the brake master cylinder mounts.
Doc
Doc
DocMSavage,
Has your rearend been replaced? 9” rearends didn’t come in F1s. If indeed it is a 9”, and not a Dana, you can just replace the 3rd member. Only issue is getting a 3rd member with the correct axle spline count. Just an FYI the pinion yokes come in several lengths which will require you to swap the yoke or have your driveshaft adjusted to the correct length.
I used a Bendtsen adapter kit to mate a 4R70W to my 8BA flathead. It fit well with good instructions.
No, the current rearend in the truck is the original one. I just have purchased a 9" to rebuild and install with my desired ratio.
I made the decision to go that route on cost and parts availability-maybe should have bought the one out of a new truck like Pete has?!
M
M
Received 4,132 Likes
on
Yes, it is all electric which eliminates the temperamental and critical throttle control cable adjustment. Also the PRNDL, backup lights and neutral safety switch functions are included in the range sensor mounted on the left side of the trans. Baumann (U.S. Shift) makes the controller kit including wire harnesses with connectors that just plug in to the trans and controller (see picture). Everything is well marked and preprogramed but you can change things with a PC and their free software. They even give you a USB cable to hook up the PC. The trans has a lot of features including a temperature sensor that reads out on the controller. You can adjust the speedometer readout also to compensate to axle and tire changes.
on
I noticed that the Speedway kit is for a C4, and not the AOD. Physically it will bolt up, but do some research on the flywheel. I put and AOD behind a 302 with a C4 flywheel, and had HORRIBLE vibration problems. I'm not sure what the differences are between the 2 flywheels (it's been about 3 years since I did this), but it wouldn't hurt to make sure before you install it. It's a lot easier to start with the correct one!
johnson.jeff.a
34
11-07-2015 12:30 PM
