flywheel suggestions for an internally balanced 460 swapped into an 85 F250
hello everyone!
I'm working on my old work truck, Sanford, which is an 85 f250 that was originally offered with a 460/ 4 speed, but sometime in it's life, got an engine swap.
here's what I know.
the Heads are D2VE heads.
here is the block casting numbers
Attachment 286585
Here is the spacer behind the harmonic balancer.
Attachment 286586
I also verified that it does have a 3.85" stroke, so that puts it at a 460. I will check the crank casting number in the morning, as I'm guessing it will help out.
My issue is that i'm now questioning if i have the right flywheel or not. I never noticed any engine vibrations while driving, but the old flywheel that i removed today will more than likely not be able to be surfaced, and so i was going to buy a replacement. The clutch that was on it was a 12" clutch, and i'd like to stay with a 12" if possible (truck sees a lot of towing). I'm looking for suggestions, what to get a flywheel for to match the engine?
here's what I know.
Attachment 286585
Attachment 286586
All 1968/82 460's came with the C6.
What some people do, is use the 352/360 (11" clutch) or 390 (11 1/2" clutch) flywheel.
*1983/86 460 flywheel: 11" .. 1987/97 460 flywheel: 12."
Pic: Scroll down to 6375:
The problem with you using this '85 flywheel on your motor is it will be weighted. Aftermarket cast the later models weighted flywheels, so they can be bought dirt cheep. I have no idea why no one will cast one that will take a 12" and bolt to FE & 385's motors ? I went through that when I switched over, in the end I just bit the bullet and payed the $300 for the billet Ford neutral balanced 12". It is a nice piece though.
all interesting note. NumberDummy, when i pulled apart my current setup, it had a 12" clutch on it, and when you look up an 85 F250 with a 460 on rockauto's website, they show listings for the 12" clutch and flywheel.
But regardless, it is the wrong weight of flywheel for the engine's balance. I cant put it back on. and really, the truck is not a high dollar hot rod, i cant justify a billet one like mark A. bought with this project. maybe once i put my Tbird together.
I did find a solution. I'm just going to swap to a externally balanced 460!! I just happen to have one that I pulled from a 78 Coachman camper this summer!!
The 460 block casting number for external balance is: D9TE-6015-AB
Block casting number for 1971/78 and some 1979 460 internal balance: D1VE-6015-AB or A1B or A2B
How is the balancer attached
I’m curious how that is attached to that sleeve collar, and does anyone know if someone on this forum might have built a 429/460 engine with an external oil pump and drove that pump behind the balancer instead in front using a mandrel bolted to the front of the balancerI have seen these big blocks both ways with different configurations, the one moroso builds has a sizable base that I’m not sure will work without an aftermarket pulley
Last edited by Randy Phillippe; 01-21-2018 at 06:02 AM. Reason: Need to add an additional question
pinkpanther
02-13-2009 05:28 AM
pinkpanther
02-11-2009 06:17 PM
460429_freak
17
01-19-2003 09:16 PM
Mudman
11-01-2002 12:12 PM
