Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
2008 6.4 white smoke at idle
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 12-16-2017, 08:38 PM
John_Forbush
John_Forbush is offline
John_Forbush is starting off with a positive reputation.
Short term fuel trim on #8 injector is 8. The rest are between -1 and 1. Truck has no blow by, passes compression test on scan tool, has codes for egr sensors and dpf stuff (previous owner took dpf system off and didn't reflash the truck). I just bought it yesterday for nearly nothing. Runs smooth, has plenty of power but want to get this figured out to prevent future problems. Smoke smells like raw diesel. Not losing coolant or oil.
Old 12-17-2017, 03:40 PM
Robert Green
Robert Green is offline
Robert Green is starting off with a positive reputation.
Sounds like the only problem is your #8 injector then
Old 12-17-2017, 08:33 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
Any contribalnce codes?
any thump thump in intake?
Old 12-17-2017, 08:35 PM
John_Forbush
No codes, no miss, no compression issues. I did notice the oil smelled slightly of diesel fuel.
Old 12-18-2017, 08:30 AM
Copper.Farm's Avatar
Copper.Farm
Copper.Farm is offline
Copper.Farm is gaining momentum as a positive member of FTE.Copper.Farm is gaining momentum as a positive member of FTE.
Potentially no codes, a bad/constricted injector would only show up on the Ford IDS scanner as a lower cylinder contribution.
Old 12-18-2017, 10:55 AM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
Can't have Stuff taken off truck, egr and dpf without a reflash AKA TUNER. You are smelling diesel because it's probably trying to regen.
Old 12-18-2017, 11:19 AM
John_Forbush
I understand that, but my question is about the #8 cylinder fuel trim being high. What tuner do you recommend? I'm looking at an h&s mini maxx. I don't want the truck cranked up because I know the 6.4's are temperamental but I do want the dpf and egr gone.
Old 12-19-2017, 11:00 AM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
I have an H&S with no problems.
Old 12-20-2017, 10:35 AM
Copper.Farm
I have the H&S with the tow tune, works perfectly for me as I’m not carrying weight or towing about 98% of the time.
VQT
11-20-2013 10:18 PM
Fire Mechanic
08-07-2011 10:10 PM
89ford73
06-29-2008 07:41 PM
PSD6litre40
08-23-2005 05:31 PM
GAPS-54
11-10-2003 03:24 AM
Quick Reply: 2008 6.4 white smoke at idle
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
