Engine Removal Thread! (With humor and sadness)
#31
This thread kicks azz man. I could go on and on, but it's nice to see someone doing a complete job and fixing another idiot's mess-ups. We are built the same regarding this. That crap would drive me nuts! That is why I never buy "modded" trucks. Most don't care to do a good job. They just want it to be cool and go fast with no thought given to integrity of the work done. Props and following.
#32
#34
AK and no snow? I'll just add two things...I have heard that there is no exhaust manifold gasket from the factory but they are available for retrofit. Sous and Skyskijason can give you the lowdown on a tube down the back of your engine to route the top side oil drain past your clutch, that is one very good mod.
#37
I did a complete engine rebuild on my truck two years ago... and i would agree that 29 days would be really tight to get her done without a few all-nighters. It took my maching shop 7 days to have my block done. If she was running fine and not blowing bluish smoke i think you will be Ok with your current pistons and rings.
Once you open up the oil Pan you will get to see your cylinder walls and what state they are in. More than likely they are good to go as is.
If i were in your shoes i would do the following:
Oil Cooler rebuild
New Cups
New Oil pump and Seal
Main Seal
Re-seal everything else.
Maybe i would get the heads off and have them rebuild.... but that's a maybe.
Oil Cooler rebuild
New Cups
Main Seal
#40
Although it looks okay in the pic, it would be about an hour or less to pull the oil cooler and rebuild it with new orings and gaskets, since the motor is out.
Oil in coolant is the risk otherwise. Unless it has been redone already?
29 days is SHORT TIME, considering shipping times to Alaska
Really like all the pics and the lightning speed you're working at it
Oil Cooler rebuild
New Cups
Main Seal
Oil Cooler rebuild
New Cups
Main Seal
My goal is to have everything planned out or ordered by tomorrow and give everything time to make its way. Then we wage complete war. Every day, for a couple of hours, something gets installed on the truck.
#41
on
Be firm but not destructive. Some have broken the ends, but not many.
I thoroughly flushed the center tubes with water, then acetone to get rid of all the water.
#42
#43
After getting some sleep, I think I'm going to cool my jets on rebuilding a motor that doesn't need it.
I may have the injectors bench tested and just reseal the motor.
New starter, batteries, glow plugs, gaskets, oil cool, HPOP, injector cups, o-rings, and a couple other odds and ends, should have this girl ready for the next 10 years of service.
#45
Those are on the list. The alternator is new, but I'd like to go ahead and eat the bullet on batteries and starter. ZF6 will have new fluid in it. Planning on new brake pads as well.
