1979 Dentside Cummins Swap Hydroboost Power Steering Question/Help - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Reload this Page >
Old 04-12-2018, 11:08 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The Ford/Saginaw P/S gearbox has a flaw, there are no bearings on the sector shaft, it rides directly on the housing. So before too long, fluid begins leaking from the sector shaft seal.
Red Head Steering Gears takes the housing, machines it to install the needle bearings that Ford omitted...on purpose, so they could sell a gazillion sector shaft seal kits!
So-called auto parts store "rebuilt" gearboxes are nothing more than resealed gearboxes!
Old 04-23-2018, 11:47 AM
Jakkpine
Jakkpine is offline
Jakkpine is starting off with a positive reputation.
Originally Posted by Aaron-71 View Post
Redhead or bluetop?
A stock one off of a parts truck. I was unaware that the f150 boxes mounted with 3 holes on the outside of the frame so I'm stuck with my bad one for now. Starting to lean towards a redhead if I can't get this box to work. There's a couple things I want to try before I spend all the money on a redhead though. I'm a millwright by trade so not being able to figure out this seal is getting pretty annoying
Old 04-24-2018, 10:01 AM
Jakkpine
Jakkpine is offline
Alright I got it figured out. Feel pretty dumb but glad it's back together. I ****ed up the seal arrangement at the bottom of the sector shaft. I had the large ID spacer behind the seal and the pressure was folding the seal over the spacer and tearing it. Small ID spacer has a push fit on the shaft and backs the seal. Took it for a drive and all seems well. Thanks for the help.
Old 04-24-2018, 10:10 AM
Aaron-71's Avatar
Aaron-71
Aaron-71 is offline
Aaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to behold
No more pics of the rebuild?
Old 04-25-2018, 11:30 AM
Jakkpine
Jakkpine is offline
I only pulled the sector shaft out to change those seals and those were the only two pictures I took. I think I have some pics of when I did the full rebuild on my computer at home. The kit came from Broncos graveyard if I remember correctly.
79Supercab
09-24-2016 11:26 PM
speedyweasel
WTB - Parts & other
06-10-2014 11:02 AM
Hurk76
01-20-2014 09:52 PM
BumpJr
06-04-2013 04:15 PM
mattbrock
11-23-2011 04:46 PM
Quick Reply: 1979 Dentside Cummins Swap Hydroboost Power Steering Question/Help
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
